Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator Logo
A
Anonymous Posted on Jan 15, 2014
Refrigerator not cooling temperature control not working
Monogram fridge only partly not cooling
If your Monogram refrigerator is only partially not cooling, it could be due to a few different reasons:
  1. Dirty condenser coils: Over time, the condenser coils can become coated with dust and debris, which can restrict the flow of air and cause the refrigerator to overheat. If this is the case, cleaning the condenser coils may resolve the issue.
  2. Faulty condenser fan: The condenser fan is responsible for circulating air over the condenser coils to cool the refrigerant. If the fan is not working properly, the refrigerator may overheat and not cool properly.
  3. Damaged or worn door gaskets: The door gaskets create a seal around the refrigerator door to prevent warm air from entering. If the gaskets are damaged or worn, warm air can enter the refrigerator and cause cooling issues.
  4. Blocked air vents: The refrigerator compartment has air vents that allow cold air to circulate throughout the compartment. If these vents become blocked with food or other items, it can restrict the flow of air and cause cooling issues.
  5. Faulty temperature control thermostat: The temperature control thermostat regulates the temperature inside the refrigerator. If the thermostat is faulty, it may not be able to properly control the temperature and the refrigerator may not cool properly.
If you have checked these potential causes and the issue persists, it is recommended that you contact a professional appliance repair service to diagnose and repair the problem. They will have the necessary tools and expertise to identify and fix the issue.
Ge profile after thawed out 8ce from freezer ot will still not cool back down
Condenser Coils are Dirty
If the refrigerator is not cold enough the condenser coils may be dirty. The condenser is like a radiator and must stay clean in order to dissipate the heat which was removed from the inside of the refrigerator. As the coils get dirtier the refrigerator becomes less efficient, which makes it work harder to cool down. If the coils are dirty enough, the unit will never be cold enough and will not be able to cool the inside of the refrigerator to the proper temperature.
Evaporator Fan Motor
If the refrigerator is not cold enough, the evaporator fan motor might have failed. Every refrigerator has a set of coils called an evaporator. The refrigerator may have one or more evaporator fan motor(s) depending on the model and evaporator locations. The evaporator fan motor circulates the cold air from the coils thru the compartment. If there is only one evaporator it is in the freezer side. If the fan is not working, no cold air will get to the refrigerator compartment. The freezer may still get cold.
Condenser Fan Motor
If the refrigerator is not cold enough there might be something caught in the condenser fan motor blade, or the condenser fan motor might be defective. The condenser fan motor draws air over the condenser coils to cool them. The condenser fan motor is located underneath the refrigerator near the back. Pull the refrigerator out from the wall and remove the access panel to access it.
Start Relay
If the refrigerator is not cold enough, the start relay may be defective. The start relay is a small device mounted to the side of the compressor. It provides power to the run winding along with the start winding for a split second at start-up to help get the compressor started. If the start relay is defective the compressor may run intermittently or not at all and the refrigerator will not get cold enough. The start relay should be replaced if defective.
Temperature Control Thermostat
If the refrigerator does not get cold enough the temperature control thermostat might be defective. The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
Start Capacitor
If the refrigerator isn't cold enough the compressor might be having difficulty starting. The start capacitor serves as a battery to give the compressor a little boost during start-up. If the start capacitor is burned out the compressor might not be able to start and run as often as it should. Test the start capacitor first with a capacitance meter, they don't fail often. If it's defective, replace it.
Thermistor
If the refrigerator is not cold enough the thermistor might be defective. The thermistor is a sensor which monitors the air temperature. It is connected to the control board. If the thermistor is defective the refrigerator does not cool or may cool continuously.
Temperature Control Board
If the refrigerator is not cold enough the temperature control board might be defective. The temperature control board provides the voltage to the fan motors and compressor. These boards are often misdiagnosed. Check all other components to be certain this is the cause of the problem.
Compressor
If the refrigerator is not cold enough, the compressor might be defective. The compressor is a motor which compresses the refrigerant and circulates the refrigerant through the evaporator and condenser coils. There are several other components which are more likely to be defective if the compressor doesn't work. If the compressor itself is defective a licensed professional will need to replace it.
Main Control Board
If the refrigerator is not cold enough the main control board might be defective. This is not common. Check the defrost system, cooling fans, and cooling controls first.
How do you work temp control on GE Profile top freezer
The ACTUAL TEMP light will come on and the display will show the actual temperature. To change the temperature, tap either the REFRIGERATOR or FREEZER pad until the desired temperature is displayed. To turn OFF cooling system, access SETTINGS from the HOME screen. Page over and tap COOLING SYSTEM ON.
I have no cold air in my refrigerator or Freezer. It defrosted everything.
Condenser Fan Motor
Start Relay
Start Capacitor
Thermistor
Compressor
Main Control Board
1helpful
Why is my Fridgidare side-by-side freezer working but my refrigerator side not cooling?
Hi Friend, this is Z. Thank you for your question!
If the temperature in the freezer compartment of your Frigidaire refrigerator is cooling but the refrigerator side is not, it may possibly be because the temperature control is set too cold/high in the freezer section or the damper door is not closing. Turn the control to a warmer setting and allow several hours for the temperature to stabilize. If the temperature does not stabilize within 24 hours, then more than likely the control is not telling the damper when to close and/or your refrigerator might possibly have a faulty thermistor or temperature control. I would personally contact a professional to accurately diagnose your refrigerator to determine the root cause to reduce the risk of unnecessary parts.
I need to learn how to control the tempature setting
The temperature controls are located at the top front of the refrigerator or freezer compartments.
The recommended setting should be correct for normal household refrigerator use. The controls are correctly set when milk or juice is as cold as you like and when ice cream is firm.
Wait 24 hours for your refrigerator to completely cool before adding food. If you add food before the refrigerator has completely cooled, your food may spoil.
NOTE: Adjusting the refrigerator and freezer temperature controls to a colder-than-recommended setting will not cool the compartments any faster.
If the temperature is too warm or too cold in the refrigerator or freezer, first check the air vents to be sure they are not blocked before adjusting the controls.
To turn Off/On:
Style 1 Press the freezer down arrow touch pad until a dash (-) appears in both the refrigerator and freezer displays. Neither compartment will cool.
Style 2 Turn the freezer control to the word Off. Neither compartment will cool when the freezer is set to Off.
Energy Saver option (on some models)
The Energy Saver option turns off the heater which helps to reduce moisture on the door hinge seal. The refrigerator uses more energy when Energy Saver is off.
Press the control to On to save energy when the environment is less humid.
Press the control to Off when the environment is warm and more humid, or if you notice moisture on the door hinge seal.
Adjusting controls
If you need to adjust the temperature in either the refrigerator or freezer compartment.
NOTES:
For Style 1 control, press the up and down arrow touch pads; for Style 2 controls, turn the dial to adjust the temperature.
Except when starting the refrigerator, do not adjust either control more than one setting at a time.
Wait 24 hours between adjustments for the temperature to stabilize.
Hope this guideline will helpout.....
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Top Jenn-Air Refrigerators Experts
john h
ZJ Limited
ZJ Limited
Jose Ramirez
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
