Whirlpool GHW9100L Front Load Washer Logo
A
Anonymous Posted on Jan 12, 2014
Service light on, flashing f23 door won't open
1 Related Answer
caroldon
  • 17130 Answers
  • Posted on Jul 05, 2012
SOURCE: f23 on whirlpool washing machine
Seems that your heater has failed. Check continuity of the element, wiring to the element and test the voltage from the controller panel board .
Click this link: error codes
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Start button will click but won't start
Hello. Your model dryer has a service flash on the lower door strike/catch concerning not staying closed or not closing properly. If the door is allowed to open too much, the door switch will not be closed and the dryer won't run. The part number for the new kit is 279570 and it includes 2 door strikes and several catches. You choose the ones you need. However, if the door *is* closing properly, you can put the unit in diagnostic mode(door closed, all indicators off) by pressing/holding any button *except* stop for 2 seconds, then releasing, press/hold 2 sec, release, press/hold 2 seconds, release-- all the indicator lights will light for 5 seconds, and an 8 88 will be shown in the display. If there are *no* active fault codes, the indicators will momentarily turn off and then stay on with the 8 88 displayed. If there is an active fault code, it will be flashing in the display. (ex. would be an "F" and "xx" where "xx" would be a number.) If you press the same button you originally pressed once, then again, then again, the most recent code will be displayed, then the next, and so on up to 4 stored codes. To turn off diagnostic mode, just press stop. I hope this helps you!
F01 PRIMARY CONTROL FAILURE
F02 KEYPAD
F22 OUTLET THERMISTOR OPEN
F23 OUTLET THERMISTOR SHORTED
F24 INLET THERMISTOR OPEN
F25 INLET THERMISTOR SHORTED
F26 MOTOR DRIVE SYSTEM FAILURE
F28 MOISTURE SENSOR OPEN
F29 MOISTURE SENSOR SHORTED
F30 RESTRICTED AIRFLOW
F70 NO COMMUNICATIONS BETW ELECTRONIC ASSEM
F71 " " " " "
F72 THRU F78 CONSOLE ELECTRONICS FAILURE
F23 on whirlpool washing machine
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
8helpful
2answers
Bosch flashing F23 fault and door wont open tried to reset by manually draining and resetting power but no joy
this has just happened to my Bosch, means the base pan is leaking water...I've had 4 problems with mine in the past and WILL NOT BUY BOSCH AGAIN, poor customer service too.
9helpful
F23 fault
F23 that it indicates a leak into the base of the appliance.
You'll need to unplug the appliance and take the rear cover off.
Check for a spillage and if there is an anti flood device in the base, ensure it's reset/working or replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
