Trying to open cd tray to get cd's out without destroying
SOURCE: how do i open the cd tray on a sony mhc-rg70av
Most CD trays will open if you shut off equipment and pull gently but firmly to overcome the slight initial resistance. Don't use so much force that it seems likely that the tray mech will break. This calls for a serious bit of taking apart and is best left to the local repair shop.
SOURCE: Sony CMT-EP515 CD Shelf System. CDs wont play.
It could be 3 things.
1. the Laser carrier may be stuck and may need to be gently pried from centre to outskirt and back.
2. your cd spinning motor has gone and needs to be replaced,
3. your laser carrier motor has gone and needs to be replaced,
hope it helps.
SOURCE: Sony CMT-hpx7 - CD changer is stuck with 2 CDs
it a bit complicate to open
you can try but you need to remember what you open so you can put back in the same order
try this
first open the back cover you should be able the see the inside then you need to open the top cover now the changer can be open without power you need to locate the motor and turn the the belt or the wheel slowly and it wil take the disc out. """"""dont turb back""
you need to plug the power and let it go back alone after that disconnect the power and put back everything
its not so easy so before you do it make sure that you can open and put back
Hope it will help
