20 Most Recent Sony MHCGX99 Shelf System Questions & Answers
Chances are, yes, it did overheat. You may have blown out a solider joint on the High and Low voltage supplies. Possibly even weakened them to the point that they need replaced. It would even be wise to test your Left and Right Channel amps.
Sony MHCGX99... | Answered on Aug 23, 2011
Pls try here. Available are Instruction Manual, Instruction Manual in Spanish and Marketing Specifications.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Sony MHCGX99... | Answered on May 21, 2008
Tienes que abrir el aparato y cambiar la banda de impulsion de la bandeja y darle mantenimiento al mecanismo del cd.
Sony MHCGX99... | Answered on Mar 29, 2008
Hi, Does it eventually power up? Check all your component (ie: CD Player, Tape etc) connections and especially the connections to the speakers. If you have any loose strands of wire touching the case it will cause problems.
Sony Audio... | Answered 2 days ago
Hello Sunil, for what you comment, there may be several reasons why the term PROTECT appears on the display
There is a solution for that problem that consists of removing the humidity that forms inside the equipment, I send you the link of a video that explains how to do it
I hope you can solve the problem
Greetings Franco Dosil
Hola Sunil, por lo que comentas, puede haber varios motivos para que aparezca el termino PROTECT, en el display
Hay una soluci?n para ese problema que consiste en sacar la humedad que se forma en el interior del equipo, te mando el link de un v?deo que te explica como hacerlo
Espero puedas resolver el problema
Saludos Franco Dosil
Sony Audio... | Answered 3 days ago
If you have an older android phone or tablet, you can download an app. If not, go to any electrical or department store and buy a universal remote. You can also look on Ebay and Amazon
Sony Audio... | Answered on May 20, 2019
Yes, sometimes that is the only way. There is a reading lens and a tracking lens. Also make sure you discs are clean and not scratched. You can clean with acrylic polish.
Sony Audio... | Answered on May 14, 2019
Hi Humberto, comment the brand and model of the phono preamplifier, also if it has a separate power supply or inside the preamplifier cabinet
I ask you this, because if you were armed in a plastic cabinet, you could pick up interference caused by cell phones or other type of component that can emit electrical noise and these interferences are those that could generate the noises that you hear in your speakers at the moment that you listen to the discs
I await your comment
Hola Humberto, comenta la marca y modelo del pre amplificador de fono, tambi?n si tiene fuente de alimentaci?n separada o dentro del gabinete del pre amplificador
Te pregunto esto, porque si estuviera armado en un gabinete pl?stico, se podr?an captar interferencia que producen los tel?fonos celulares u otro tipo de componente que pueda emitir ruidos el?ctricos y estas interferencias son las que podr?an generar los ruidos que escuchas en tus parlantes en el momento que escuchas los discos
Espero tu comentario
http://diagramasde.com/diagramas/audio/Sony%20HCD-CP100.pdf
Sony Audio... | Answered on May 13, 2019
Hello, yes, supposedly you should walk, you can try without risk of something being damaged, at most it will not work
Discuss how the test was
Hola, si, supuestamente deberia andar, puedes probar sin riesgo de que se perjudique algo, a lo sumo no funcionara
Comenta como fue la prueba
Sony Audio... | Answered on May 12, 2019
Sony MHCGX99 Shelf System Logo
12 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
need owners manual
  • Audio Players & Recorders
