HP Laserjet 3330 Mfp All-in-one Laser Printer, Only 11,260 Print Count Logo
M
MAXINE CAMPBELL Posted on Jan 13, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NOT PRINTING LASER NOT WORKING
LASER NOT WORKING
Chris Coughlin
Level 2:
  • HP Expert 1,326 Answers
  • Posted on Jan 13, 2014
Chris Coughlin
HP Expert
Level 2:
Answers
1326
Questions
Helped
441759
Points
872
Replace the laser unit or replace the printer..... It may cost more to fix the printer then to buy a new one?
Why is print head loose or missing?
The print head houses the printer LASER if it is missing NO Printing. OR Loose normally the print head is located well inside the machine so you cant see the LASER beam when it is working.
Take the machine back to who sold it if the LASER ?PRINT HEAD is missing
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1helpful
Printing blank pages
Hi, it might be the laser head is faulty or hvps is faulty. Try do an test print from the printer by press and hold the buttun for 5 sec or so. If it doesn't print. Try to clean the laser head which is able to be found under the printer with 3 screw. Do not power on the printer and look at the laser head this might cause blindness. After clean place back the laser head and test print. If same issue, try with a new sets of toner. If this still don't work you have to engage an technicians to either replace the laser head or hvps.
2answers
My boss want to replace the black ink cartridge for one that prints color. Can this be done with the HP 12-a cartridges? HP Laser jet 1022
Unfortunately laser printers don't work this way. The laserjet 1022 was designed for black and white prints only. In order to do color printing with a laser printer you will need to purchase one that is designed to print in color. The laser printers work a bit differently than the inkjets - the laser printers have 4 toner cartridges, one each for Cyan, Magenta, Yellow, and Black, that work together to print a full color page. With the old inkjets you could just replace a black cartridge with a color one.
So, short answer: Sorry but no you can't make a laserjet 1022 print in color. :)
I would recommend looking at an entry level color laser printer from hp, such as the CP2025 (http://h10010.www1.hp.com/wwpc/us/en/sm/WF25a/18972-18972-3328060-15077-236268-3673580.html) if you are looking into purchasing a color laserjet.
Hope this helps
Please rate this post, thanks!
1helpful
Red prints as Orange
If this is magenta being weak (light) on all the things you print (try doing a test pritn, and a configuration page from the printers own menu system). this will be the dirty laser lens/mirrors problem that is very common with this printer.
Solution is either
Dismantle (it IS quite a lot of work, but fairly straightforward methodical screwdriver work) the printer to remove the laser unit. Take cover off the laser unit and CAREFULLY clean the lenses and mirrors. NOTE take care not to disturb the alignment of any part of the laser optics, and be especially careful with the mirrors as they are surface silvered and V easily scratched.
You can find NEW laser units on a certain internet auction site, and also (genuinely) refurbished exchange printers. Both of these two opttions will obviously save time and effort, but be more expensive.
24helpful
3answers
300 dpi in canon 2900B
I cannot understand how will print picture 300x300 dpi in CANON 2900B. There is solution but not working.....
1helpful
Bends envelopes in printing
Most laser printers have an "S" paper path. They cannot help bending paper. I would suggest you print lables instead of envelopes if you send several letters. If you only send 1, hand address the envelope. Not elegant ut it works.
Printer prints from manual feed but not from tray.
you need ot open up the papper tray and more the laser down then it should work
please rate my helf i need you to i am a exert
Hey,
Try installing the toner/pc drum once more, then print something and when printing open first cover and take out pc drum, look the pc drum, if the pc drum is clean, then the laser wount reach it. laser is located above the pc drum. when you close front cover then there is a little swich in right side what opens laser cover, try to makse sure that it works.
if there is a print marks in pc drum, hten the problem is in transfer rollerits located behind the pcdrum.
1helpful
2answers
Printing dbase reports on a samsung laser printer
dBase as in the old DOS based database program from the late 80s - early 90s? If so we'll need some more details on which version (II, III or IV)and the Operating system the program is running in to start with.
k24674
Grand Canyon Tech
Grand Canyon Tech
