My rear left brake line broke and when i called the parts store for a new one they asked me the size and length which i don't know so if someone could help me with the size and length that i am suppose to get?
I can't tell you the length but the diameter of brake lines is commonly 3/16" and rarely bigger - some older vehicles and heavier vehicle use 1/4".
The size of the pipe is intuitive by simple comparison or measuring with a caliper but there is several different threads, lengths, diameters of pipe nuts in common use and it is important to get these right first time.
It is also very important the replacement pipe is formed exactly as the original, follows exactly the original route and is adequately secured.
When one brake pipe fails usually others aren't far behind and the failure of a pipe should signal a very close examination of the others, especially looking for corrosion scale or pitting close to the wheels. Replacing four or five pipes on a large vehicle can use a whole 25 foot roll of pipe.
It might be better to invest in a cheap pipe flaring kit and the materials to produce your own pipes - or remove the old pipes and ask a local repairer to make new pipes to those patterns. That was my job as an apprentice and I must have produced a mile of pipes for outside customers.
Auto parts stores stock exact length brake lines now. You may have to measure. Your best bet is to get it off and take it with you. Remember you will have to bleed the system to be sure no air gets in the line.Be sure and call for parts availability before removing the brake line.
If you can see both ends of the hose, then just take it off and go to any auto parts store. they will have an assortment of vacum hoses in different sizes. Match the size and then have them cut a length. You don't need to take it to the dealer or buy the hose from the dealer.
Most of the brake line that you get at the local auto parts stores usually sell 3/16 and it comes in 5 or six feet sow you would have to splice them together and come already with the fittings.They also sell them in smaller lengths.
If you want to do this yourself, just remove the brakeline. Go to a parts store and buy the length of brake line that you need. Most brake lines are 3/8" or 1/4" so get the right size. Get the brake line fittings. You will need tubing cutter, tubing bender, and flairing tool. Just cut it to the right length, bend it to the right shape, and install it. Presto!!! New brake line! Hope this helps. Good luck.
You can purchase different size (diameter) and length brake lines at an auto parts store. They are inexpensive. The lines are already 'flared' to be connected to another line, all you have to do is disconnect the old line, and attach the new one. Spray the connections several times a day for a couple of days to make them easier to separate. you will also need to bleed air out of the replaced section for the brakes to work properly.
what i usually do if the money is available is purchase the brake lines in all sizes from the auto parts store and return any unused parts to the auto parts store,for a refund. they usually know the sizes you need ; you could also do the front first then the rear, or replace one line to get the size, also need a tubing bender to bend the brake lines, 'bleeder screws are usually three choices or go to ford or mercury, once you get started its not too bad, beware of compression fittings (unsafe to do it that way) Good Luck .
Any good auto parts store (or go online) will have different sizes and length brake lines. They won't have the exact factory line, you will have to use several different lengths with a junction (connector) between each length. They come in lengths of one foot up to about 5 feet, and yes, you should replace all lines if one has rusted through, as the others will fail soon. Check NAPA, Auto Zone, Advanced Auto Parts, JC Whitney, etc. countrycurt0
most brake lines are 1/8"(0.125) suprised parts store couldnt cross reference for you generally you can buy the line prefab with all fittings the right bends and length alot easier to install hope this helps
To get the length, just get a roll of string, run it along the existing brake line 'til u get to the rubber line. you can cut off the line near the master cylinder, bring it to the parts store, they can tell you what size you need. You will have to use several lengths of line to reach the back. If this line has rotted thru, you should change all the others, as they are likely to fail soon. countrycurt0
