Navman NavPix  N60i GPS Receiver Logo
f
francine whittle Posted on Jan 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Open replace battery - Navman NavPix N60i GPS Receiver
Chris Walker
Level 3:
Top Expert:
  • Navman Master 1,573 Answers
  • Posted on Mar 15, 2019
Chris Walker
Navman Master
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1245811
Points
21965
How do you replace battery in chamberlain remote, garage door model 2487355
Do you have the Chamberlain 248735S garage door opener? Chamberlain doesn't have a 2487355 garage door opener; there are the 248735 and 248735S openers.
Most of the Chamberlain remotes are simple to open. Use the visor clip or a flat blade screwdriver to pry the two parts of the remote housing apart. There should be an open space on one edge of the short sides of the remote where you can insert the blade to begin separating the remote housing. Once started, you may be able to separate the rest of the housing by pulling the two sections apart with your hands. See page 32 of the user manual to see a picture of the separated remote or http://support.chamberlain.com/articles/How_To/How-do-I-remove-and-replace-the-battery-in-my-remote-control-1484145519292/?q=change+battery+in+remote&l=en_US&c=Brand%3AChamberlain&fs=Search&pn=1 for the procedure. Replace the battery with a 2032 coin cell battery, if you have the 248735S. Replace the battery with the correct replacement coin cell battery for other garage door opener models. Make sure that the side of the battery with the + faces the section of the remote housing with the buttons. The manual for the 248735S is currently here: https://www.chamberlain.com/CatalogResourcesV3/en-us/shared/files/tucmanuals/114A4256.pdf . Support and manuals for other models of Chamberlain garage door openers can be found from their support page: https://www.chamberlain.com/parts-and-support .
I hope this helps.
How do I open my Apple G3 I phone
There is no way to get to your battery. Apple makes their phones really closed. To replace a battery you must have special tools and special skills. and to replace the battery, you first have to buy one. You won't find these batteries in a phone store.
If you insist in doing it yourself, feel free to visit ifixit.com, to see how they open an iPhone for repair and battery replacement.
4helpful
3answers
How do I change the batteries on my WW60X? I can't find my manual but was able to open the battery cover to get the number for the batteries. Now I can't get the batteries out of the scales. ...
Your Instruction Manual is here:
http://www.conaircanada.ca/pdf/en/ibs/en_WW60XC.pdf
Battery Replacement Instructions
1. Turn over the scale and open the battery door. (Push ribbed switch and pull up)
2. Replace old batteries with two new 3V Lithium batteries (CR2032).
3. Close battery door.
4. Properly dispose of old batteries.
There is nothing holding the batteries in place once the battery door is opened. If the batteries are difficult to remove, use a small screwdriver to gently pry up on the battery or simply after opening battery door invert the scale and shake.
2answers
We need to chage the battery in our 2006 corvette key fob. How do you open it?
There should be a slot on one end that you can put a penny into or something similar, and it should pop open.
5helpful
2answers
How do i open the key fob to replace the battery
For 2009 Cadillac CTS
Remove the hidden key by slipping a small screwdriver or knife under the metal endcap and lift. The key will come out. To replace the battery, pry the two halves of the main plastic housing apart, exposing the CR 2032 battery.
How to open to replace battery?!
Check the manuel for opening the battery cover. Otherwise go through the product review in the company website.
2answers
Hello, Ineed to change the battery of the time and date. I want hnow the number of the battery to buy one and changing. Regards Josephine.
Sounds like you uwant to change your CMOS battery. You should bring this to a professional so as to not damage your computer. If you don't know what you are doing to will cause more damage than a worn out CMOS battery
4helpful
How to open for battery replacement
Found this link that may help you out. Seems like they are made to be used then tossed out. What a waste. Anyway the battery replacement issue is a common problem... http://k0lee.com/2008/04/replacing-remington-and-norelco-shaver-batteries/
6helpful
Braun 7526 battery problem
Open the shaver:
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Remove and replace circuit board with batteries (or solder in the new batteries)
Top Navman GPS Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Mike Cairns
Mike Cairns
Are you a Navman GPS Expert? Answer questions, earn points and help others
