20 Most Recent Navman NavPix N60i GPS Receiver Questions & Answers
hi can u sell the carmount and charger with cd to me pls for navman n60i
prakash
Navman NavPix ... | Answered on Dec 07, 2011
Give it a hard reset, bring it back to factory settings,
if no change yet then buy ur self a external GPS antenna which will sure solve the problem. External antennas are not that expensive.
Good luck
Do i need to keep power to my Navman N60i as i change the battery,or is it ok to remove the battery and place the new one in. Will i wipe out the memory.Thank you.
Navman NavPix ... | Answered on Mar 14, 2011
Go to Navman register your unit free reg, and then you can download anything you need.
Navman NavPix ... | Answered on Feb 17, 2010
down load new software, from navman
Navman NavPix ... | Answered on Dec 06, 2009
usually a faulty SD card or faulty memory
Navman NavPix ... | Answered on Jul 01, 2009
Go to dis link....http://smartst-desktop-2006-se.software.informer.com/ and der u can download smartst 2006 SE..
Hope dis is helpful....And kindly rate my solution..
Navman NavPix ... | Answered on May 13, 2009
i have lost my instal cd for my navman n40i
Navman NavPix ... | Answered on Apr 25, 2009
There are two small screws on the bottom of the case. Remove these and pry open from the bottom carefully. Note that yhe case surrounds the USB jack so take care with that side of the case when opening. The speaker is on the back part of the case and is connected to the motherboard. As you remove the back make sure to disconnect the cable before you pull far and tear the connector - it's small.
Navman NavPix ... | Answered on Mar 30, 2009
Generic Answer:
Read your instruction manual about "Lost Password". The unit will have to be sent back to the factory service for re-activation. With some models they allow re-activation if the unit is re-started at its home position. If you did not program a home position, then you have no chance to unlock it yourself.
With many of these devices, if the wrong password is used more than a specific amount of times, the unit is permanently locked out.
When you send back the GPS for factory service, you must include a photocopy of the proof of purchase. They may also want some ID information to verify that you are the actual owner. For this they will call you.
At the factory service, they will have to re-load the original factory firmware to unlock the device. There is no master password. Many of the manufactures will charge for their technician's time to do the work. The client will also be expected to pay the shipping costs.
Suggestion:
We tell our clients to NOT use a password. If the device gets lost it really does not matter, because it is lost anyways and it may never come back. People tend to forget their password and usually end up locking out the device anyways.
With a GPS, for personal security program the home position to be at least a few hundred yards from where you actualy live, or do not put in an address number or any name of any person. This way if the GPS is stolen, the thief will not be able to know where you live, or who you are.
Comment:
I have seen many locked out mobile phones, GPS's, car radios, laptops, and much more! Most of the time, the manufactures were charging fees to unlock the device. Sometimes the unlocking cost was fairly expensive.
We tell people to not use the lock feature, unless they are very critical to the content they have in their device.
Jerry G.
Navman NavPix ... | Answered on Sep 14, 2008
I have seen this with cameras, and pocket TV sets.
It is best to send the unit back for factory service. Ask for an estimate before servicing.
The parts in your GPS are not generic parts. You can buy the screen from the manufacture and find that the circuit board under it is also broken or damaged.
You may also find that the cost of the screen replacement may approach the cost of a new unit. I have seen this on many small devices. In some models the screen module comes as part of a complete matched assembly.
Jerry G.
Navman NavPix ... | Answered on Sep 02, 2008
No you cannot. Although you can receive/make calls through the b2, there is no display on the satnav itself.
Navman NavPix ... | Answered on Aug 07, 2008
Navman NavPix  N60i GPS Receiver Logo
25 questions posted
Top Navman GPS Experts
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Navman GPS Expert? Answer questions, earn points and help others
View Most Popular
Navman GPS
  • Navman GPS
Most Popular Question
navman n60i replace battery
  • GPS
