Randell 8395NPCB Prep Table, Refrigerated Raised Rail, 95" Logo
J
Jayce Erwin Posted on Jan 11, 2014
Part RP HNG 006 Anchor Screws
The hinges for the top doors started to come up and the screws wouldn't tighten down, how are they fastened and where can i find this anchoring screw or part?
1helpful
2answers
How do I remove the front driver side power window switch on a 2008 Buick Enclave
Armrest Door Pull
Remove Rubber Cover
Remove 10mm *****
The first step is to pry out the plastic trim plate behind the chrome colored door release handle using a small flathead screwdriver.Then remove the 10mm ***** behind the plate using a ratcheting wrench with an extension bar attached.
Next pry out the rubber cover at the bottom of the door pull located in the center of the arm rest. Use a Torx T-25 (star bit) screwdriver to remove the two screws.
Remove Torx T25 Screws
2 T-25 Torx & 1 10mm *****
Pry Up Arm Rest Panel
Use a flathead screwdriver to pry up the rear of the plastic arm rest panel. There is a plastic hook at the front of the panel, so only pry it up from the rear edge.
Lift Rear End First
Plastic Hook At Front of Panel
Power Window Connector
After you lift out the arm rest panel, you'll need to disconnect the power connector for the window and door lock switches.
Push Connector Release Tab
Power Connector Unplugged
Two More T25 Screws
Push on the release tab with a flathead screwdriver and pull out the power window / door lock connector.Use a Torx T25 screwdriver to remove the two screws located below the arm rest panel.
Remove T25 Torx Screws
Outer Edge of Panel
Push In Center of Fastener
Then move to the outer edge of the door panel and locate the two small round fasteners. Use a small screwdriver to pop in the center pins of the two fasteners.
Pull Out Plastic Rivet
Black Plastic Fastener Removed
Remove Lower Fastener
Pull out the two plastic rivet fasteners and set them aside in a safe place.
Pull Panel Away From Door
White Plastic Pop Rivets
Pull Off Sail Panel
Grab the door pull in the arm rest and tug it towards yourself to disengage the pop rivet friction fasteners that hold the panel to the door frame.Move to the top corner of the door panel and pry off the triangular "sail" panel. On some vehicles, the sail panel contains the tweeter speaker.
Lift Panel Off Door Lock
Pull Out Door Pull Cable
Lift the door panel off the door lock button and tilt the top of it out towards yourself.Use a pair of needle nose pliers to gently lift the metal ball at the end of the door opener cable out of the mechanism.
Disconnect the door cable from the back side of the door panel.
Door Pull Cable Removed
Disconnect Power Mirror
Then disconnect the power connector for the side view mirror by lifting up on the release tab. Slide the power connector off the plastic anchor on the metal door frame.
Slide Connector Off Anchor
Unlock Connector
Connector Detached
Look behind the door panel and locate the large wire connector with the pink lever lock. Swing the lever open to unlock the connector and separate it from the socket.
Door Panel Removed
Power Window Motor
10mm Bolts
Now the door panel can be completely removed by lifting it up and off the door frame.To replace the power window motor, remove the 10mm bolts.
Stock OEM Door Speaker
Remove 7mm *****
The stock "OEM" speaker is held in place by a single 7 mm *****. Remove it with a socket and ratcheting wrench.
Pry Off OEM Speaker
Speaker Removed
Disconnect Power Plug
If the speaker is stuck to the door frame, gently pry it off with a small flathead screwdriver.Disconnect the speaker's power plug by pressing the release tab with the small flathead screwdriver.
Fits 5.25", 6.5", 6.75"
Re-installing Door Panel
According to the Crutchfield website, the 2008 to 2012 Chevrolet Malibu's front door speakers can be replaced withaftermarket speakers in the following sizes: 5 1/4", 6 1/2" or 6 3/4" speakers with the use of a bracket.If you'd like to reduce road noise, make your car quieter and also improve the sound from your speakers, I'd recommend applying some Dynamat Sound Deadener on to the metal door frame.
Re-Attach To Anchor
Plug In Power Side View Mirror
Re-Insert Power Connector
To re-install the door panel, first hold the panel close to the door frame before re-connecting the large wire plug. Swing the pink lever closed to lock it in place.Slide the socket for the power side view mirror back on to its anchor and insert the power plug.
Lock Power Connector
Pink Lever Locked
Re-Insert Door Pull Cable Ball
Insert the metal ball at the end of the door opener cable back in to the door handle mechanism.Slide the black plastic cone part of the cable back into the slot in the door opener assembly.
Door Opener Cable Reinstalled
Hang Door Panel On Frame
Gently lower the door panel down on to the edge of the door frame with the door lock switch through the opening at the top.
Line Up White Plastic Fasteners
Push On Sail Panel
Push Door Panel In Place
Move to the bottom of the door panel and line up the white plastic pop rivet fasteners with the holes in the metal door frame.Push all around the door panel to re-insert the pop rivet fasteners.
Re-attach the sail panel at the top corner of the door frame.
Push Panel Flush Against Frame
Insert Side Edge Fasteners
Insert Larger Piece First
Next move to the side edge of the door panel and first re-insert the larger piece of the two fasteners. Then insert the smaller "pin" piece of the fastener into the middle of the larger piece.
Insert Small "Pin" Piece
Install Lower Edge Fastener
Tighten 2 T25 Torx Screws
Re-Attach Power Connector
Insert Front Hook First
Insert and tighten the two Torx T-25 screws located under the arm rest.Re-attach the power connector to the plastic arm rest panel.
First insert the hook at the front of the arm rest panel and then snap the rear end in place.
Pop Arm Rest Panel In Place
Tighten 2 T25 Screws
Replace Rubber Cover
Insert and tighten the two T25 Torx screws into the door pull cup. Then replace the rubber cover over the two screws.
Tighten 10mm Door Handle *****
Replace Door Handle Trim Plate
Malibu Door Panel Replaced
Replace the 10mm ***** that goes above and behind the door opener handle and tighten it. Pop in the plastic trim plate behind the door handle.
tip
How to Reverse Your Refrigerator Door (Most units)
1. Remove the toe grille.
2. Remove top hinge cover if available. Trace around the hinge with a soft lead pencil. This makes the re-installation easier. Remove top hinge and lift door off the center hinge pin, and set the door aside.
3. Unscrew the center hinge pin using an adjustable wrench and save for reassembly. Ensure that the plastic washer stays on hinge pin.
4. Lift the refrigerator door off of the bottom hinge and set aside.
5. Remove center hinge and shim by removing inside screw and loosening two outside screws enough to allow hinge and shim to slide out. Tighten screws.
6. Loosen two outside screws on opposite side of refrigerator, remove inside screw and install center hinge.
7. Remove two screws on bottom hinge with 3/8" socket wrench.
8. Install bottom hinge on opposite side with the two screws removed from Step 7.
9. Unscrew the bottom hinge pin using adjustable wrench. Move hinge pin to other hold in hinge and tighten with adjustable wrench.
10. Reverse door handles.
11. Move freezer and refrigerator door stops to opposite side. Before starting screws, use an awl to puncture the foam.
12. Position refrigerator door onto bottom hinge pin and screw center hinge pin through center hinge into the top of the door. Close refrigerator door to help align hinge hole.
13. Tighten center hinge pin with adjustable wrench.
14. Remove cabinet and hinge hold plugs and move to opposite side.
15. Lower freezer door onto center hinge pin (if you have a separate freezer door).
16. Close freezer door. Have an assistant lift up on opposite side of the door while tightening screws to install top hinge.
17. Flip top grille and reinstall.
18. Plug in electrical power cord and turn refrigerator temperature control to center position. Adjust setting as needed.
How do i fit the door on the other side
Hi Mel, I looked for a manual for your fridge but couldnt find one. These jobs are pretty similar - regardless of brand however.
You should first deremine if your model does indeed support swapping the hardware to allow the door to swing the other direction. Look at the points of attachement for the handles and hinges on the door and the fridge body itself. There are typoically pre drilled holes for fasteners in these parts on the opposite side - but have plugs or covers over them to minimize their appearance. if you have these tell tale indicators present - you're good to go.
The process will require removal of all products stored on the doors of the fridge and freezer compartments, and placing in a thermal container or cooler.
The hinges consist of one at the top, one at the bottom and usually one in the center that engages both the bottom of the top door and the top of the bottom door.
At the top, you may need to remove a bezel or cover to gain access to the fastener head(s). Many times these are hex head screws, but could be any type really. Two, 3 or more fasteners may be used to hold the top inge to the fridge. Once the screws are loosened / removed the tops door will shift - so be ready for it (or have afriend support it while you remove the fasteners). The doors are surprisingly light - a thein meta outer jacket wrapped around a lightweight drame, lots of insulation and plastic is it really is. Lift the top door up and away from the center hinge pin. You may find one or more spacers or washers made of metal or more likely - nylon. Remove these and set aside as they will likely be needed to put back in place when the hardware is reversed.
The lower door is being help by the center and bottom hinges now. You should have access to fasteners holding the center hinge to the fridge. Support the bottom door as you loosened and remove the fasteners on the center hinge If you are unable to access the fasteners of the center hinge, try the fasteners on bottom hinge instead. If you get the center hinge loosened, you should be able to lift on the door slightly to roll it out from between the center and bottom hinge. otherwise, when the bottom hinge fasteners are removed, the door will drop and be free from the fridge. Look for similar spacers or washers on the bottom hinge pin that yuou found on the top of the center hinge pin and save them.
Remove any remaining hinges from the fridge.
Remove door handle hardware from both doors and remove plugs / covers from the opposite side of the doors. Secure the door handles to the otherside and insert the plugs and covers into the holes that had previously been used to fasten the handles.
Remove the covers / plugs from the fridge and insert into the opening that previously fastened the hinges to the fridge. Swap any covers / plugs on the doors for hinges if needed.
Reinstall the hinges and doors in reverse order of removal. If the bottom hinge was last to come off - it is first to go on. Reinstall the spacers on the pin. The bottom door is placed on the bottom hinge pin. Place the center hinge pin into the recess of the top door and secure the hinge to the fridge. Place the spacers over the top pin of the center hinge. Place the top door recess over the center hing pin. Align the top hinge with the recess on the top of the door and insret fasteners through top hinge into fridge. Hand tighten all fasteners. Operate doors and check for rubbing, binding, etc. Adjust number and location of spacers as needed to allow doors to swing without scraping or binding. Once satisifed, tighten all fasteners. Adjust feet of fridge as need to allow the doors to close by themselves if left open by accident. Restock fridge & freezer.
Done!
2answers
Change doors from left to right
Depending on the brand, this "may" be possible. Look for a mounting bracket area on the side you want to change to. Is so, have someone help you, two person job!
Tips Provided by: www.HoustonRefrigeratorRepair.com Brian Gillespie (GOFAR Services, LLC)
I have whirlpool A CLASS fridge how do i reverse the door
  • I cannot confirm weather your fridge had reversible doors as you listed no model but the standard for fridges that can reverse the door swing are changed by doing this -
  1. You will see little plastic covers on the opposite side where the hinges and handles are currently located now.
  2. There are some little clips that hinge the screws on the top and bottom of each handle.
  3. Remove these little covers with a small flathead screwdriver.
  4. Now remove the screws holding the freezer and refrigerator handles on.
  5. Now pop the screw hole covers on the side of the frig/freezer you will using.
  6. Now place and fasten with screws the handles on the other side of the frig/freezer door.
  7. Now remove the top freezer hinge first by removing the 3 screws on top.
  8. Now pull up on the hinge (save the spacer).
  9. Now pull up on the freezer door.
  10. Now remove the screws on the middle hinge.
  11. Now pull up and remove the middle hinge while holding the frig door steady (save the spacer).
  12. Now pull up on the frig door and set to the side.
  13. Now remove the screws on the bottom hinge (save the spacer).
  14. Now put the screw hole covers you removed from the other side in the screw hole exposed from the screws you just removed.
  • The switch
  1. Start with the bottom hinge and place it on the opposite side (don't forget the spacer).
  2. Place the frig door on the bottom hinge and the place the middle hinge in the hole at the top of the frig door.
  3. Fasten the middle hinge.
  4. Place freezer door on the middle hinge.
  5. Put the freezer door in it's natural position to make putting the top hinge on possible.
  6. Screw the top hinge in.
  7. Job complete.
Regards, Tony
REFRIG. DOOR SAGS SO THERE IS A GAP FOR COLD AIR TO ESCASPE
If you have a 5/16th nut driver pop the top hinge cover and remove the 3 screws then take the top door off. Back off the middle hinge and reposition it do the door no longer sags. Tighten them screws and put the top back on using the same procedure. Hold the door in the correct position you want whist tightening down them screws on top. Snap the cover back on. Raise the front egs a hair to throw the weight of them doors towards the rear of the ice box and take some the work off them hinges. Then Party on!
Ice Box service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
How do i change the hinge on thhe refrigerator door? Thanks for your help!
Unplug the refrigerator and remove all food and utility bins from the doors. With the door open, remove the grille from the bottom of the refrigerator. Close the door.
Step 2
Remove the cover from the top hinge with the putty knife. Remove the three screws underneath, then remove the hinge. Take off the freezer door.
Step 3
Remove the three screws from the center hinge, then remove the hinge. Take off the refrigerator door.
Step 4
Remove the two screws from the bottom hinge, then remove the hinge. Replace with the new hinge and insert the two screws.
Step 5
Seat the refrigerator door on the bottom hinge and close the door. Fasten the new center hinge with the three old screws.
Step 6
Seat the freezer door on the center hinge and close the door. Fasten the top hinge and replace the top hinge cover.
Step 7
Replace the base grille, and plug the refrigerator back in.
Good luck in solving the problem with the solutions provided....
22helpful
2answers
DRYER FIN IN DRUM IS COMING LOOSE
Unplug the dryer, remove the door hinge screws that go into the cabinet and the two screws on the opposite side of the door opening, then the front panel can be removedby starting at the top. Once the front is off, there are two screws, one to each side that hold the top on, remove these and raise the top. You can rotate the drum by hand and the baffles are held on by the screws on the outside of the drum. Reassemble in reverse order.
3answers
2helpful
Loose door handle
DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. Usually with these doors, the latching parts tend to loosen up at times, thus requiring some re-adjustment and tightening. Sometimes they get a bit warn and require to be replaced. The handle by itself about $40, apparently GE doesn't know how to make a door handle that will hold up for more than a year or so. I just bought a new door off of eBay for $20 + $20 shipping ... a deal compared to the $135 + tax and shipping that most of the web sites want! All you need is a phillips screwdriver and a 5/16" socket. To get to 3 screws that anchor the TOP hinge, simply remove the vent grill (open the door and remove the 2 white screws that hold it in place). To get to the 2 screws that anchor the BOTTOM hinge, simply remove the 6 screws that hold the grey bottom pan of the microwave in place. The pan will swivel down, remaining attached in the back panel. Once you've removed the 5 hinge screws, the door should pull pretty much straight out. Reverse the procedure with the new door, which should come with hinges attached. Could be that the place the spring sits in is a little broken, so theres no stop for the spring. open it up and see if there's anything you can do with it, try some epoxy putty maybe. Good luck
Top Randell Cooking Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Randell Cooking Expert? Answer questions, earn points and help others
