Every time the needle goes down, instead of passing over the top of the bobbin to make a loop, it passes just underneath the top of the bobbin, therby looping around the bobbin. The bobbin is loaded according to the manual, and the top thread is threaded properly, but the problem still occurs, even with no fabric.
SOURCE: Not picking up the Bobbin thread
I cleaned the machine good with canned air, oiled it. I took out the bobbin case and cleaned it good also. I then noticed the tension screw on the bobbin case was loose, tightened it and the problem was fixed.
Sounds like you have to take off the throat plate and clean out threads under it. Sometime they ball up and prevent the needle from going down and catching the bobbin thread. You can't see themuntil you take off the plate. Follow the directions. It is easy.
SOURCE: Thread looping on top and bottom of fabric
hi! there,
on this condition,you can avoid wasting time and material try on this, the problem is your set up of tension thats why.,but you should follow upper theading. see figure,this just sample of exact threading,next bobbins set up see fig.the thread should be clockwise rotation on winderfollow this set up,and upon inserting be sure
you have clean feed dogs and shuttle race free from fabrics and threads chips.set dial tension to #3 to #4 and stitch dial to #12.then try this set.and you can watch on you tube sewing. try this stuff on internet address type www.youtube.com then on search box type sewing machine,have enjoy and have a nice day.don't forget to rate me,
SOURCE: looping underneath
I watched a 'You Tube' demo that showed ........if you loosen or tighten the very small screw at the base of the bobbin this gives you the correct tension & stops the looping under the fabric........I didn't even know this screw existed ! It is trial & era at first re the correct tension but you do get there.... the art is to do it in small mini stages.....like you hardly move it ! Thanks to 'You Tube' I can now get on and finish my drapes !
SOURCE: Singer 301a...sews on top of fabric
This is a tension adjustment problem. It's good to use two different colors of thread, like you did. From your description, the top thread (needle thread) tension needs to be tighter. As you tighten the tension of the top thread, you'll see that the top thread pulls the bobbin thread up into the fabric so it's no longer laying loose on the bottom of the fabric.
You'll need to have the pressure foot down when you tighten the tension. Tighten it a little, sew a practice seam, check to see what the stitch looks like. Tighten it a little more, sew, check, etc etc--until both top and bottom look the same--you shouldn't see much (if any) of the bobbin thread color on top of the fabric or the top thread color on the underside.
Let me know how this works for you, ok?
Robbie
