Vizio VW32L 32 in. LCD HDTV Logo
Posted on May 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dont know the contrast ratio of this tv
LCDHDTV-MODEL VW32L40A dont know the contast ratio of this tv
Bob B
Level 3:
President:
  • Master 272 Answers
  • Posted on May 23, 2009
 Bob B
Master
Level 3:
President:
Answers
272
Questions
0
Helped
224662
Points
1890
Specifications
Panel Type: 32" Diagonal (31.5" Viewable), 16:9 Wide Screen, Color TFT Active Matrix LCD
Panel Specifications: Anti-Static and hard coated surface
Pixel/Dot Pitch: 0.507mm (H) x 0.5107mm (V)
Display Compatibility: HDTV (1080i)
Signal Compatibility: 80i (SDTV), 480P (EDTV), 720P (HDTV), 1080i (HDTV)
Response Time: 8 ms (typical)
Colors: 8 bit 16.77 Million colors
Brightness: 500 cd/m2
Contrast Ratio: 5500:1 Dynamic Contrast Ratio
Viewable Angle: 178° (horizontal and vertical)
  • Bob B May 25, 2009
    The only thanks we get is a rating from you. If my response helped you with your problem please rate me accordingly. If you aren't able to give me a fixya at this time please feel free to ask me more questions until you can. Thanks for using fixya!
I WOULD LIKE TO KNOW EQUIVELENT OF TDA9340PS/N3/A/1923
If you enter the IC number into Google you can find places that have the original model, so why would you want an equivalent?
I have a grundig GU19WDVD10 tv and the picture mode has got mixed up and the quality is not right. What numbers should the brightness, contast, colour etc be on? Thanks
In most cases, 75% contrast, 40 to 50% brightness and 35 to 45% color will be best. Adjust the picture sharpness control in between 10 and 25%
What is the contrast ratio on this tv?
Rear projection cathode ray tube televisions (RPCRTV) have excellent contrast ratio. If you are seeking the actual specifications for that you may have to find a manual for it. RPCRTV's are still the top of the line for contrast ratio, still above all new technologies.
4helpful
The screen comes up with a large dark square on it ,no cursor, no input is possible, all batteries are new
Contrast too high.
Press [CLEAR] key and adjust contrast (Reduce)
Reduce the contast as follows
1.Press [2nd] key and release it
2.Press [DownArrow] and release it
3. Keep repeating the sequence until contrast is adequate.
To increase contrast Do the same but press [UpArrow] instead of [DownArrow]
Hope it helps
Numbers are messed up on the screen. can't read what it says.
Press the [CLEAR] key to erase everything on the screen. Adjust screen contrast as follows
Reducing the contast
Hope it helps
3helpful
The screen is not working
Contrast may be too light or too high.
Press [CLEAR] key and adjust contrast (Reduce or increase)
Hope it helps
How can I tell if my new LG 42" 5020 lcd tv is 15000:1 ratio or 50000:1 ??
technically it is both it's just people get confused with dynamic contrast and static contrast. The LCD LG5000 Series (00,20,30) has a
[dynamic contrast ratio of 50,000:1]
this would typically be
[15,000:1 contrast ratio] for a plasma.
so to count for, lcd tvs use dynamic contrast and plasmas use static contrast it's just a way to measure them both.
like people weighing themselves soem weigh in kg some in pounds =p hope this helps.
Contrast ratio of tft monitors
Contrast ratio is the ratio between black and white. So low contrast ratio (5000:1) means you can;t see the screen so well in a bright room (where there's a lot of sunlight) A higher contrast ratio (20000:1) means the screen is brighter so easier to see in bright rooms.
Pixel pitch refers to the distance between pixels. The lower the pixel pitch, the sharper the image
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
