Kenmore Elite 45986 Front Load Washer Logo
Posted on May 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Loc code frigidaire
How do you unlock the loc code on a frigidaire washer
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Sep 11, 2010
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5037107
Points
35540
Hold the LOCK button for 5-8 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
How do i remove the loc code
I appreciate your post, friend!
Based off the information you have provided you are receiving a "LOC" code on your Frigidaire washer. "LOC" typically means that your control lock feature is on to remove the lock feature you need to hold down the options and select buttons for ten seconds. I hope this is helpful. -Matt
2helpful
2answers
Loc error code on Frigidaire frontloader
To avoid having someone accidentally start or stop the washer, press OPTIONS and Select at the same time and hold for about 10 seconds until the Control Lock) lights up. "LOC" will be displayed alternately with the estimated cycle time. Turning the Cycle Selector knob or pressing any button will produce flashing indicator lights and/or beeping. To unlock the controls, press and hold OPTIONS and Select for about 10 seconds. Frigidaire GLTF2940ES3 Quick Start Manual Page 3
3helpful
My frigidaire GLTF2940ES0 displays LOC when i press start
Hello & Welcome to FixYa
LOC error code is displayed when the control panel is locked, to unlock it press the OPTION & SELECT button and hold them for 20 seconds. This should reset the control, if it does not then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
5helpful
Loc coming up on frigidaire washer front load
The controls have been locked unintentionally and this is a safety feature to avoid having someone accidentally stop the washer or modify the cycle. It can be unlocked by pressing and holding the OPTIONS and SELECT buttons for 10 seconds or until the "LOC" is no longer displayed. Lock the controls with the same buttons and in the same way until "LOC" is displayed alternately with the estimated cycle time.
12helpful
Washer will not start error code says "LOC"
hold the option and select buttons at the same time for several seconds and it will "unlock" the control panel hold it for a very long time keep them pressed as you turn the dial
3helpful
Loc code
the control panel is locked. on the control panel, there will be either a "lock" button that you hold down for 3-5 seconds to unlock, or it will have "lock" in small letters with a line pointing to 2 of the option buttons. hold the 2 buttons it points to for 3-5 seconds and it will unlock. the control lock is a child safty feature that will not allow any the washer to work until it is unlocked. P.S. to put the control panel into the lock mode, is the same way as you unlock the control panel.
34helpful
3answers
Frigidaire front load, ERR LOC, washer won't run
Just had same problem. After removing boot/rubber gasket around opening, and replacing door lock assembly it still would not work giving the same ERR LOC message! Another site directed me to press the "Options" and "Select" buttons at the same time. BINGO! My husband was quite proud of me!
Broken washer
your control is locked
read the manual on how to unlock it. let me know if it wont unlock.
Frigidaire Gallery washer
you locked the door, down the lock keys to unlock
Alexander
vince
