My Sony Grand WEGA KF-50WE610 LED blinks 4 times. After turning it, on you can hear the audio for like 1 second but no picture ever comes on and the LED blinks 4 times.
4 times blink shows Temp Error and requires temperature sensor replacement in Sony KF-50WE610 TV
I got your question and replied it as service manual says about 4 blinks error. TV gets high temp signal from temp sensor.
Check temp sensor and replace it.
Sorry for delayed reply as I was busy in real business.
Temp sensor is called IC41 and part number is as follows..
IC41 8-759-442-07 IC LM75CIMX-5
it is mounted on H3 board and board part number is as follows..
A-1405-433-A H3 BOARD, COMPLETE
and H3 Board is available in Part Store.
When I tried to turn on the TV, I could hear the fan start and after like 2 seconds it died off and the LED started its 4 blinks secuence in red.
Thanks for your fast reply.
Do you have the part number for the temperature sensor?
The part arrived from the Part Store last night. The board has an audio/video jacks. Does this board replace the board located at the front of the TV? How do I replace it? Would I have to take the TVs back cover off or can it be replaced thru the front of the TV?
Part installed and continues with the same problem. Just trashed $90 plus a couple of hours of my time.
my lamp won't come on and was wondering if i should replace the lamp ballast or even mabey the fam
