20 Most Recent
Sony Grand WEGA KF60WE610 60" Rear Projection Television Questions & Answers
When I turn it on it blinks green and then red but doesn't turn on
The most likely problem is the light bulb.
You will require replacing the lamp housing. It is a relatively simple task and should, as a novice, take you no longer than 15 minutes. An OEM bulb by Phillips will cost anywhere from $100 to $250. A generic bulb will cost around $30 to $50 and will work just as well. When purchasing the bulb be sure to buy one that has at least a 6 month 6000 hour warranty. Most of the bulbs come with a basic toolkit to facilitate easy installation. Good luck and happy viewing
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Green tint
It sounds like your red and blue guns are not working. Open the back cover and remove CRT neck assembly and place it back to clean contacts on the tube. However, the bet solution to my 35 years experience s a TV technician is this is a time to get rid of this TV and replace it with 55" LG, preferably, 3D. In any case, I can help you if you send me a line at
[email protected] or call me with a message at 8473806394 with your phone number.
My picture does not come in has lines
Sounds like an OPTICAL BLOCK Problem.If under warranty Sony should bear some of the cost, approx. 70% according to another post.If not , will cost approx. $1200 for Sony to fix.
