Stuck on standby mode
SOURCE: Sony HCDX1 STUCK IN DEMO MODE
I don't have a Sony HCDX1, so if this doesn't work, please do not rate me down.
Push the PLAY and STOP buttons (at the same time) and hold them for about ten seconds. This should get you out of DEMO mode.
Power the unit off, then back on. If the display now says LOCKED, then press the PLAY and STOP buttons (at the same time) again to unlock.
If this does work, please rate it Solved, so others can use this solution. Thanks!
SOURCE: stuck in protect mode
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back
and see if you get rid of protect state. Sometimes accumulation of
electrostatic charges inside circuit capacitors can kick in protect
mode. In that case unplugging the unit from main for some times can get
rid of electrostatic charges, and reset circuits by draining power
completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number
listed on the owners manual, or asking a quote on repair to a local
technician.
SOURCE: help my sony bravia just today got stuck in
When I power my Sony lcd 42 inch the red light blinks then I push the power button the green standbye light just continues to blink, any suggestions
SOURCE: My Sony KDL-26S3000 won't turn on it well get stuck in standby
Please see the troubleshooting chart, BU1 board part # A-1268-869-A, cost approx $230.
SOURCE: MDS 503 STUCK IN STANDY MODE?
Is it an MDS-JE530? Do you have a minidisc in it? If yes, then unplug the unit. Slide the little switch from TIMER "OFF" to "PLAY", then plug the unit back in. After 10 seconds, it should turn on and start playing the minidisc. Let me know if that works or if we need to try something else, okay?
