New tv connected via scart to cable box. have followed tuning instructions. it says cant find any channels but i'm getting the sound from the channels but no picture
SOURCE: DirecTV Remote Control of Polaroid TLA-01511C
These worked for me
Polaroid
10765, 10865, 11262, 11276,
11314, 11316, 11326, 11327,
11328, 11341, 11498, 11523,
11991, 11992
SOURCE: Polaroid FLM-3232 Blue Screen 'No Signal'
yeah stay away from polaroid! In the meantime check this out.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
SOURCE: polaroid lcd tv sound only no picture
Hello dougie49
I would first check the back-light and the inverter. usually these are what causes the problems in LCD displays. If the inverter is bad most likely the back-light will have problems. If you need to replace the back-light 9 time out of 10 you will require a new display element.
I hope this helps
Thank you,
Henry A. McKelvey
SOURCE: 37" Polaroid LCD TV No signal appears when select channel
I was having same problem, and think I got lucky and found fix.
Try unplugging the TV and waiting 30 seconds, then plug back in.
You will likely get blue screen with "No Signal".
Go to Menu, then scroll down to "Setup". Select "Factory Reset" then hit "Yes."
This did it for me. Wish you all luck.
SOURCE: Polaroid 19" TV TLA-01911C has no picture. Powers up, see logo
To add to this solution above - I had the capacitor replacement and there was still an issue. Turns out the solder connection to the lamps themselves was very very poor causing an electrical arc (the scratching noises people are hearing) - then the inverter shuts the lamps down as it should. Fix lights!
