20 Most Recent Bush WS6671 28" TV Questions & Answers
2answers
Problem with BUSH 6685 VPL
Hey, The same thing happened to me today. I've had the tv for about 3 months now. There's not much information available on this so I was wondering if by any chance you got your tv fixed? Thanks.
2/24/2022 6:37:32 PM • Bush WS6671 28"... • Answered on Feb 24, 2022
2answers
TV changes channels itself
Have you checked to see if any of the front panel buttons are depressed and stuck??? this is a big problem these days?? I have also found the infared remote sensor to be bad on some sets that do crazy things all by them selfs.. A funny storry once i had was a customer called me after her mother called some goast finders as her maggy projection set would go on all by itself andf the channels would change and the volume would go up and down all by its self. funny thing I had a set just like thast in the shop at the time with the same problem and I scoped out the output pulse from the infared reciver on the set and that was putting out noise on the data line and caused the set to eratacly do all sorts of weird stuff. get the point?? its a stck button or the remote sensor is bad.
12/31/2018 4:50:35 PM • Bush WS6671 28"... • Answered on Dec 31, 2018
0answers
No picture at all- black screen- and the TV just beeps...
smps problem
4/17/2017 1:28:53 PM • Bush WS6671 28"... • Answered on Apr 17, 2017
0answers
0answers
NEED THE CODE FOR A BUSH TV MODEL NO BLED32HDRAE
2267 :)
11/17/2012 6:35:30 AM • Bush WS6671 28"... • Answered on Nov 17, 2012
2answers
User manual for bush tv
http://forum.eserviceinfo.com/archives/99999975.html
This Site Should Help You Mate
11/15/2012 6:02:24 PM • Bush WS6671 28"... • Answered on Nov 15, 2012
Thereis a red outline around
the antenna in god direction?
open tvbehind cover,,,,,,thir is 3 rings around crt neck,,,every one for adjusting one cplour[R,G,B]ROTATE THE R ONE WHILE WATCHING,THROUGH A MIRROR,,,,,,YOU MUST ADJUST FOCUS FIRST,,,,,,,for tech it will be easy by using battern generator
1/7/2011 2:25:24 PM • Bush WS6671 28"... • Answered on Jan 07, 2011
I have a bush 22inch tv that has gone all green
I had a tv a while ago that did the same thing. It turns out that a magnet got near it and permanently changed the way the phosphorus coating on the inside of the screen lit up. I'm afraid it's going to stay that way-- it is not repairable. Good luck. I hope you can get another one for not much money.
4/5/2010 4:49:43 PM • Bush WS6671 28"... • Answered on Apr 05, 2010
Thin bright line appears in centre of screen when
HELLO
This seems to a be a growing problem! You have FIELD COLLAPSE. The frame/field output IC has failed and will have to be replaced.
If you are not competant with electronics then call in a service engineer to sort it!
ALL THE BEST (:-)
10/12/2009 12:20:04 PM • Bush WS6671 28"... • Answered on Oct 12, 2009
User manual req
Hi Neil I am vortash .. I find this site prety good for any manuals some are free others reasonably priced it is http://www.safemanuals.com the sites name is diplodocs .com I hope this helps Regards Vortash
5/18/2009 10:53:11 PM • Bush WS6671 28"... • Answered on May 18, 2009
I need to reset receiver code on bushidlcd32tv006 lcd tv
Hi I am vortash unclear what you mean regarding reciever code are you refering to the Remote code for the remote control .. or a security lock out code ? ...either way the solution should be available in the user manual . If you have no user manual try this site some manuals are free others reasonably priced it is http://www.safemanuals.com
I do hope this helps Regards Vortash
5/15/2009 12:01:20 PM • Bush WS6671 28"... • Answered on May 15, 2009
Televison & Video Logo
60 questions posted
Top Bush Televison & Video Experts
matt martin
matt martin
Sean Wright
Sean Wright
john h
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Bush Televison & Video
Most Popular Question
user manual req
  • Televison & Video
