The Dr lo is for the warming draw. I assume you have a warming drawer. Page 17 of your manual describes how this function works. It also states on page 11 "The Off/Cancel pad stops any function except the WARMING DRAWER, Timer and Control Lock. If you have actually unplugged the stove and plugged it back in it should come on with a PF for power failure. You push the Off/Cancel pad to clear the PF and then you have to push start to do anything else. such as bake, etc. Have you pushed Drawer OFF? That should clear the dr lo message. If this message comes on as soon as you plug the stove in or just after you push the Off/Cancell pad or after you push start or bake try to push Drawer Off. If this does not work then it apppears you have a malfunctioning control panel.
SOURCE: Controls lost mind -- keeps asking for probe temp
Houston, we have a problem... Your electronic relay control, (ERC), is shot, kaput, no bueno and must be replaced in order to correct your situation. The ERC part number is 3191106, and retails for ~305.00 dollars! (I kid you not). I guess now is the time you might consider replacement over repair. That's a good question. If you choose to proceed with the repair, repost and I'll help with details on how to do it.
SOURCE: Oven stopped 5 to 10 minutes after pressing START
sounds like a wiring problem check your power source
SOURCE: Whirlpool Super Capacity 465 gas stove
Find the paper in the envelope on the back of the stove. (Behind the console.) This will tell you what those fault codes mean. Be sure to replace the paper. If it is needed again, that is where a technician will look for it.
SOURCE: stove top works, display unit and oven does not
I would have to say that u need to remove the back painl and look for a ground wirer that is broken or burnt in half. make sur that u unplug the oven first.when u find the problem just replace the wirers
