20 Most Recent
Whirlpool Gold GW399LXU Gas Range Questions & Answers
Electricity is out in stove
need more information, don't know what you are really asking for. it can be anything from a breaker being tripped at the electric box, (which you would notice something else turned off not just the stove, since this is a circuit that is usually shared with something else.) sometimes they may be sharing power from a near by GFCI outlet and that may be tripped, all you would need to do is reset them. could you be more specific with what is wrong? we may be able to help better than this.
Kenmore gas oven will sometimes
The image below shows information about the ignition system on the oven burners of this range. That document shows some of the common causes of slow ignition. I recommend that you check the ports and the alignment of that burner and igniter. This information may help you determine the cause of your problem.
I have a Whirlpool Gas Range with Accu-Bake. On
In addation to the spark do you hear th egas flowing as well? if you do hear the gas and can light it with a match/bbq lighter but it doesn't light with the spark,it could be cleaned by using a safety pin/paper clip and push through the holes where the flame burns all around the burner(s) also steel wool will clean the burner.
Gene
When turning on, the ignitor clicks and stays on
exactly where the flame doesnt ignite there is a hole in the burner that the gas comes out of ,that hole is clogged with debris and could be cleaned by pushinga papaer clip through it to cleared the blackage,if that does not work that burner would need to be replaced.It of course would be a good idea to clean every hole on the burners all of them for both surface range and oven/broil
Gene
What when pf error come
Hello & Welcome to FixYa
PF error means power failure which is generally
caused when the control board inside the unit goes bad. You can try unplugging
the unit for 15-30 minutes, if the issue returns then the control board needs
replacement. Please get back to me if you have any other questions.
Kevin
Smells like something died in there
hello, There is nothing inside that unit that can cause an odor. Most likely something did die in there like a mouse they love to live in stoves, I see it all the time...please dont forget to rate me thanks
I recently purchased a home
I can't say for sure on that unit specifically, but you can usually take off the covers (the heavy iron grates and possibly a drip tray) above the burners to get down inside and you should see a small pilot tube with a small pinhole. This is your pilot light.
My electrical panel only shawing PF and nothing
Hello &
Welcome to FixYa
PF error
means power failure and is displayed when the electronic control is bad. You
can take it apart and blow compressed air on the control, if the problem
returns then replacing the control is recommended repair. Please get back to me
Kevin
