20 Most Recent Whirlpool RF378 Electric Kitchen Range Questions & Answers
F5-E3 CODE
Lbenes: Thank you for your review. We would like to inquire further about your review with you. Please respond back to this email address, [email protected], with your name, Review ID Number (), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We look forward to your reply. Thank You KitchenAid® Social Media Relations
3/9/2018 5:21:18 PM • Whirlpool RF378... • Answered on Mar 09, 2018
F5e1 error what sure i do
the code indicates door latch not working. Try turning the power off at the breaker for 10 minutes then power it back up. If it return you should call for service
2/6/2016 11:09:24 PM • Whirlpool RF378... • Answered on Feb 06, 2016
2answers
How do i clean my oven?
Clean your oven racks: Meanwhile, clean your oven racks. See the full cleaning tutorial here. Wipe out the oven: After 12 hours or overnight, take a damp dish cloth and wipe out as much of the dried baking soda paste as you can. Use a plastic or silicone spatula to help scrape off the paste as neede clean-oven-4r5ndnrswxkid2hncvg2upkw-5-0.png House Office Carpet Residential Commercial Cleaning Geelong Commercial...
11/23/2015 12:25:08 PM • Whirlpool RF378... • Answered on Nov 23, 2015
2answers
Whirlpool rf378lxkq1 oven won't turn off
hi try unpluging the main power supply
3/9/2015 11:26:06 PM • Whirlpool RF378... • Answered on Mar 09, 2015
Broiler element needs to be replaced
Hi, UNPLUG or turn off the breaker. Remove the screws that hold the element in place. Hopefully there is enough wire that you can pull it out far enough. There are screws that hold the wire to the element. Just remove the screws and put the new element in place.
I hope this has helped you. Please let me know if I can assist you further.
Thanks
Vic
4/1/2014 7:35:39 PM • Whirlpool RF378... • Answered on Apr 01, 2014
3answers
F5E1 error
Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
>>Exception Note:<<
Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appear, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
8/14/2012 3:55:03 PM • Whirlpool RF378... • Answered on Aug 14, 2012
2answers
Beaumark oven self cleaning
I lost my manual for the appliance, i was wondering if anyone knows how to get one? Thanks in advance
1/23/2012 5:58:24 PM • Whirlpool RF378... • Answered on Jan 23, 2012
Trying to use self clean
F5-E1 Door Latch Check LatchF5-E1 or E1-F5 error is a door lock error. If these suggestions don't help, you will need a technician to diagnose and repair the problem.Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused. That sounds like you have problem with the door latch; you should disconnect power again for 15 seconds and reconnect and see if that helps.Also could try to check tips in THIS LINK.Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.Thank you for using Fixya, and have a nice day.
11/16/2011 5:20:50 PM • Whirlpool RF378... • Answered on Nov 16, 2011
I have a whirlpool electric
**** the hinge to the broil position. Put a nail or something so the hinge won't pop back in the door when you go to put it back. Once ya have it back in the stove, remove the nail and close the door. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
9/7/2011 4:41:33 PM • Whirlpool RF378... • Answered on Sep 07, 2011
My WhirlpoolModel SF379LEK display shows
Hi
Error code F5-E1 indicates that there is an issue with the door latch switch assembly; if the switch tests open then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
8/9/2011 7:44:32 PM • Whirlpool RF378... • Answered on Aug 09, 2011
A mouse is moving white
just lift the whole assembly from the front it will kind of lift up like the hood of your car.(most models)as far as moving it out from the wall it should have at least a foot or 2 of give slide it straight out from the wall if it is gas be careful not to break the flexible line if electric it should have a big plug like your dryer.
4/25/2011 5:32:59 PM • Whirlpool RF378... • Answered on Apr 25, 2011
Whirlpool RF378 Electric Kitchen Range Logo
94 questions posted
Top Whirlpool Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Kitchen Ranges
Most Popular Question
beaumark oven self cleaning
  • Kitchen Ranges
