20 Most Recent Whirlpool GR460 Electric Kitchen Range Questions & Answers
try calling a local repair service .
Whirlpool GR460... | Answered on Jan 15, 2018
first off how old is this stove,there's alot of parts discontinued for this,like the clock assy. and if the oven isn't working this could be your problem.get someone that knows how to use a meter,let them check to see if you have 240 volts going to the oven,if so check to see if power is coming out of board if not the board is no longer available.did anything happen while you were using it or a power failure and has the clock ever gone blank on you or anything like that,if so that also is a bad clock assy. or computer board.
Whirlpool GR460... | Answered on Dec 21, 2017
call a repairman or someone that knows how to check continuity and ohms and volts with a voltmeter
Whirlpool GR460... | Answered on Jun 22, 2015
The F5 E1 error message indicates the latch motor was unable to lock the door. When the self clean cycle is started, the control board will turn on the latch motor which is mounted on the rear of this range. The motor is connected to a cam that transfers the motors motion to a rod that runs under the cook-top. Here is the part to order.
Whirlpool GR460... | Answered on Dec 10, 2012
I have a Whirlpool super capacity 465, the surface light for the burners comes on, the burners don't heat up, nor does the oven,(the light that says oven is on does not light up). I checked the main circuit breaker, that works. Are there any fuses in the range that would need to be replaced?
Thank-You,maddie
Whirlpool GR460... | Answered on May 26, 2012
The part number you need is 6610333, Whats happening is the relay on the oven control board is stuck or shorted and constant power is applied to the broiler at all times. This is not only irritating but very unsafe. I would turn the breaker off and leave it that way until the part is replaced and the problem resolved.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Whirlpool GR460... | Answered on Apr 28, 2012
Hi marilynbnage,
This issue is often caused by the latching mechanism that used to keep the door shut.These can become damaged during the high temperatures of the self clean cycle, resulting in a stuck door.
Try to use a coat hanger to poke through the grill under the control panel and try to push the solenoid arm out of the way because the latch solenoid is still engaged.
Hope it helps.
Thank you for using FixYa.
Whirlpool GR460... | Answered on Sep 16, 2011
Most likely it is F5-E1 code. self clean latch will not lock. follow procdures below,but likely problem is failed lock motor
All F5-E Codes - Door Switch Defect - This occurs when the door switches do not match. If door is latched, disconnect power from unit and check wires and connections. If damage is found, replace appropriate part. If connections are not damaged, reconnect power and hold down any key until the F5 error clears. Once the F2 code appears, select 'cancel' and observe for one minute for errors. If door is NOT latched, disconnect power from unit and check wires and connections. If damage is found, replace appropriate part. If connections are not damaged, measure door switch (door open = latch open) and latch switch (unlatch = switch open) and replace either if defective. If corrections are made during any step, power should be reconnected and the unit should be tested. Press and hold any key to clear the error code and F2 code should appear. Select 'cancel' and observe for one minute for errors. If error continues, disconnect power and replace control.
Whirlpool GR460... | Answered on Dec 28, 2010
F3
- E2 Oven temperature is too high (Cook
mode)
Replace
Oven temperature sensor (RTD)
Note: Applies to all
F3-E... codes.
Whirlpool GR460... | Answered on Dec 26, 2010
Hi
Thanks for using FixYa. Error code F1-E1 means safety flip flop and to resolve this issue you'll have to replace the Electronic Range Control (ERC). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks Rylee
Whirlpool GR460... | Answered on Oct 07, 2010
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
^T%#$
Whirlpool GR460... | Answered on Oct 01, 2010
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&*UJ
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*&YH
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#@#
Whirlpool GR460 Electric Kitchen Range Logo
75 questions posted
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Archie Ferrarini
Archie Ferrarini
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Whirlpool Kitchen Ranges
Most Popular Question
self clean
  • Kitchen Ranges
