Download an MP4 player program can simply do this. You can try Leawo Blu-ray Player which can support not only MP4, but also many other common formats such as AVI, WMV, DivX, FLV, etc.
You may convert your MP4 video to AVI video, I know most DVD player support AVI video well. If you don't know how to convert video, I think this step by step direction would help you a lot.
http://www.reviewstown.com/how-to-convert-avi-mp4-wmv-mkv-flv-mpg-youtube-video.html
Hope it helps. Feel free to email me if you need further help.
For every format (MP4 is not one, but dozens of formats and no standard) you need a player, or on a computer a setting in a program. A DVD player, only can play one format, a DVD format. Actually it is even a coded format. When you have a MP4 file, you should encode it to to the DVD format and then but it to a DVD, before you try to play it in a DVD player. Try reading some articles about video formats on Wikipedia, when it is interesting enough for you to understand different Video (and Audio) formats.
There could be a few different problems. You should first narrow down the possibilities. If you are playing the mp4 file directly from your laptop try changing the source. Put the mp4 on a usb drive or on a playstation/xbox or simply on a dvd. Try playing the file through one of these other sources. If the audio no longer lags behind the video than its likely an encoder setting that your Hisense doesn't handle well. If lagging is still present on all your sources then change the type of cable. If you are using HDMI try RCA or vice versa. You can also separate the audio from the video. Try using a VGA cable between your laptop and TV for the video and use a separate RCA to 3.5mm headphone jack for the audio, Most Flatscreen TVs have dedicated audio inputs for different video inputs. Try out these different set ups and you can determine if the problem is with the TV the Laptop or the cables in between. If it is the TV you may have a problem with the main board but this is unlikely especially if the audio video sync works fine with other file types.
your watching a divx file or h.264 video, or a torrent file, the frame rate is faster than the audio bitrate...whoever gave you that file encoded it wrong. should be mp4 video file. ">
Apple iPad doesn't support SWF files, you have to use special SWF to iPad Converter to play swf videos with ipad, plus, you need a special swf player, like this one
http://swfplayer.info/
mp4 is a video file only. this is becoz ur phone doesnot support mp4 files. plz tell the exact model number of ur phone for better assistance. convert ur files to 3gp format using software"any video converter"which is free..
The mp4 files must be maximum 320x240 resolution, any larger and it will tell you that the file is not supported. If the mp4 is created with any profile other than "AVC Baseline" it will tell you the file is corrupted. It also won't do DRM, but I can't remember what, if any, DRM systems typically get used on mp4 files.
I have the HD2. I have to install code pack called CCCP to play my video on my pc. It's come with a Zoom player too. http://www.cccp-project.net/download.php?type=cccp
