Dehumidifier not dehumidifying ...
Save the old one for parts if you get the same new one but I def. don't reccomend buying this unit again. The reviews are bad. The fan is not covered under the warranty except first year or extented warranty. I spoke with Kenmore & Sears about this to see if coverd under 5 yr. Only compressor,tubing & refrigeration system(see inside of front cover for warranty info.)
Sound more like a sensor/circuit board problem to me since fan is turning. I think the signal determins which setting fan needs via sensor assembly to run. I could be wrong. Justa thought.
Can you def. hear the compressor come on. You can look through grill to see fan spin & the compressor makes a clank/clunking noise/ The fan & compressor should turn same time. Good luck! If you got any info. on my fan problem & you have update or fixed your problem I ccould use some help. Check post for my problem.. Thanks! panfan1
