Checked rad and overflow ,level good no leaks re-set and continued shutdown
How old is the 30RES? unplug the low oil sensor on the radiator and see if it runs, they are notorious for failure and have to be filled in the radiator to the brim. If it runs order a new sensor, I have replaced many of them for this reason, but more often the radiator seems full by dipping finger in, but will always take more coolant. The sensor is mounted so high up in the radiator. I ask the age as newer ones require a signal to be maintained and it isn't just a simple ground if low on coolant, if it has 3 wires then disconnecting for the above test will not work
SOURCE: Kohler 11rmy-q53 generator.
The first thing I would do is to clean and dry air filter. If it is a foam material you can use a warm water and a few drops of dish soap.Rinse thoroughly and let dry. I also would try a small amount of octane booster in my gas. Hope this helps you.
SOURCE: Kohler 30RZ62 generator Parts
You are going to have to register with Kohler and use this site to get your part:http://www.kohlerpower.com/residential/sectionfront.htm?sectionNumber=13561
