Electrical Supplies Logo
paul Aitenbichler Posted on Nov 26, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I require a service manual for a FG Wilson generator modek P250HE
FG Wilson P250HE
yassit elsafi
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 03, 2014
yassit elsafi
Contributor
Level 1:
Answers
Questions
0
Helped
244
Points
0
A2000 It is seem to power wizard but its more easer than PW 1.0
Renee F
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 573 Answers
  • Posted on Dec 09, 2013
Renee F
Expert
Level 2:
Prodigy:
Answers
573
Questions
0
Helped
248200
Points
680
Can you tell me what control is on that unit. A 2000 or 4001?
Also how old is it? I maybe able to help if I have that
I need the workshop manual of perkins england 2332/1800 diesel engine of genset generator Olympia Gep150 controlled by Fg wilson uk.best regards
We are Perkins diesel generator OEM and can provide 22KW to 1800KW Perkins diesel generator including open type,silent type and container type genset. Each genset has its user's manual.
Normal starting procedure of Perkins Generator set
1. As far as possible do not start the generator set under load conditions.
2. Transfer the key switch to the starting (STAR) position. The engine should start immediately.
3. After the engine starts, return the key switch to the running (RUN) position. If the engine has not started after 10 seconds, turn the key switch back into operation and (RUN) for 10 seconds. Then repeat steps 2 and 3. If the engine is still unable to start after three attempts, please find out why.
4. After engine starts, follow steps 4.a and 4.b.
A. Check the oil pressure.
B. Check the machine for leaks.
C. Make sure the battery is charged.
D. After running the engine for five minutes, check the generator monitoring system. Make sure the engine works properly before loading.
Note: do not use ether-like spray starting aids in cold weather. Otherwise, it could lead to explosion and personal injury.
The use of water jacket heaters or extra battery capacity improves the machine's start-ability below 10 ?.
Methods for checking and cleaning the core of the rear cooler of Perkins generator set
Check for damage, corrosion, dirt, grease, insect stains, leaves, oil and other debris on the cooler. Clean the cooler if necessary.
https://www.dieselgeneratortech.com/generator-sets/Instruction-for-Perkins-Generator-Set-Maintenance.html
55kva gfwison generatore having trouble of no output voltage showing nor it feeding
If it is an FG Wilson 55KW Olympian you need to check the AVR and make sure it has a field output feeding the exciter stator, then check the rotor diodes, check each one with a meter, low res one way high the other with meter leads. If any are bad change them all, check the exciter rotor, then the main rotor and stator for open or shorted windings. If you give me the exact model I can maybe help more
I need a manual for my fg 6000mk 11 hp, 5700 watt, 5.70kva, 7097-fg6097
Hi Gary,
The manual can be downloaded from this link:
http://www.mccullochpower.com/ddoc/MCCO/MCCO2008_USen/MCCO2008_USen_FG6000MK-7096FG6024_966991401.pdf
You need to have Adobe reader installed on your computer.
You can get it on the Adobe website, www.adobe.com
Hope this helps!
Do you have fg wilson generator 200 kw electrical manual
Open this Link
A list of model no appears.
Select your Model to download or open the manual.
Not ejecting
DRUM FG
In the case there is no DRUM FG input in the
drum rotation mode for 4 seconds or more. This
error is defined as [E04], and the mechanism
mode is shifted to STOP with the pinch roller
set off.
1. The drum cannot be started or drum rotation is stopped
because tape transport load is too high.
1) Tape tension is extremely high.
2) The tape is damaged or soiled with grease, etc.
2. The DRUM FG signal is not received by the syscon
CPU.
1) Disconnection in the middle of the signal line.
2) Failure of the DRUM FG pulse generator (hall element).
3. No drum control voltage is supplied to the MDA.
4. No power is supplied to the DRUM MDA
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
