My Janome JD1818 will sew in reverse but not forward.
The machine sews fine when I press reverse but in forward it sets in same place on the fabric with needle repeatedly going into the same hole with no movement of the fabric. Any ideas? Thanks, Linda
Make sure the stitch length is set higher than 2. Also make sure the feed dogs have not been inadvertently dropped for darning. If the feed dogs are up and moving back and forth, they are working okay but may have a lot of lint and dust inhibiting them from biting the fabric.
Are you sewing very fine or slick fabric? Frequently, that will cause the fabric to slip under the presser foot. Check your machine to see if you can adjust the pressure on the presser foot. If not, then try laying a piece of wax paper or vellum with the fabric. It can be easily removed after stitching.
You have the reverser in the back stitch setting. When you do an over lock stitch you change the feed direction. It should be a lever. Some have a screw lock to keep it in place.
1/28/13 - I have Janome Harmony 2049 that was initially sewing forward with no reverse and then after about 12 inches of sewing would ONLY sew in reverse. After spending an hour getting the plastic housing off...I was able to locate the shaft that made the reverse. It needed lubrication and after working it in and unjamming the part from the down position, the forward and reverse now work! Huh, right? Hope it continues to work well. It is a smooth running machine, otherwise. Good luck!
I couldn't find my manual for the Dual Sew 3500, either, and long story short, I discovered the manufacturer of Dual Sew is the parent company of Janome; that the Janome 4618 Limited Edition is virtually the same machine; wrote to Janome and they emailed me the PDF manual for th 4618LE. What a relief.
Darning would normally be done with the triple stretch stich, the one that is a zig-zag broken up into three stitches right and then three stitches left. See-through Zig-Zag foot. Zig-Zag set at it's widest. Feed set to about 1/16-1/8 inch (1.5-3mm) and darn by sewing forward a bit, adjust fabric, and then backward by pressing and holding the reverse button. Continue back and forth until you've created a darned box. For extra strength, turn fabric 90 degrees and repeat over same area.
I cannot get the sewing machine to forward the fabric
