Konica Minolta Bizhub C550 Color Copier/printer/scanner Logo
Sajo Olatunbosun Posted on Nov 18, 2013
I have konica minolta bizhub c550,it showing me P21 and P6,what is the causes?and the black is not printing well
carpediemweb
Level 1:
  • Contributor 54 Answers
  • Posted on Jan 06, 2014
carpediemweb
Contributor
Level 1:
Answers
54
Questions
Helped
72844
Points
82
P6 : cyan image unit problem. P21 come after P6, and it's also too a cyan unit image problem. replace the cyan image unit.
My machine bizhub c451 display error code p6,p7, p9,p16, p21
Registration errors. Have tech come out clean IDC sensors and replace black i/u
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
C550 cooling fan not functioning, what can i do to make work?
Konica Minolta bizhub cooling fan not working Questions ...
www.fixya.com/tags/cooling_fan_not_working/printers/konica.../bizhub
Konica Minolta bizhub printers & copiers cooling fan not working related questions and answers. Ask your Konica ... Question about Bizhub C550. 1 Answer ...
Konica Minolta Bizhub C550 Cooling fan power - Questions ...
www.fixya.com > ... > bizhub > Konica Minolta Bizhub C550
konica minolta bizhub c252 error c-5351 C - 5351 Is power cooling fan problem.Verify the cooling fan connectors and clean.For reset open/close the front door.
cooling fan not operating properly - HP Support Forum
Konica minolta bizup c550 printing black copy what will i do?
The corona housing for the back drum need to be replaced. Get a new black image unit drum and developer units
Iam getting p21 c650 and developer
Color registration is off check the sensor under the transfer belt and mite want to have e tech run color registration procedure. black is the reference for the color registration having developer problems with black drum does not help
Konica minolta bizhub c550 how to fix ghosting on black
replace the black image unit and run gradation test
What is the causes of p21 and p6 in konica minolta bizhub c550
replace the black image unit and clean sensors under the transfer belt
What is the causes half printouts in black color in konica minolta bizhub c550
write unit block the signal just try to look for the object that block the signal from write unit
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
