20 Most Recent Konica Minolta Bizhub C451/c550/c650 Toner Magenta A070330 Questions & Answers
Color registration is off check the sensor under the transfer belt and mite want to have e tech run color registration procedure. black is the reference for the color registration having developer problems with black drum does not help
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Jan 10, 2016
requires remove of the transfer belt and cleaning of the registration sensors located under the belt on the right side of the machine, with belt out requires knowing what lever to push to expose the sensor to clean them or the have them replaced.
Konica Minolta... | Answered on May 25, 2015
help me my konico minolta bizhub 184/164 error (C2558)
my mail id - debajitdutta141@gmail.com
Konica Minolta... | Answered on Jun 27, 2019
c0211 = Manual tray rise decent error - check PC14 lift up sensor, M2PC tray 2 vertical transport motor and also the tray 2 control board
Konica Minolta... | Answered on Jun 13, 2019
yellow toner or motor
Konica Minolta... | Answered on Jun 06, 2019
Enter service mode -counter- parts couner-new release-select fuser-open front door-press start button. Exit technical mode. Good luck
Konica Minolta... | Answered on May 31, 2019
try to install the driver again & be sure that is compatible with windows version
Konica Minolta... | Answered on May 15, 2019
A4 paper equals 8 1/2 x 11 paper wrong paper setting
Konica Minolta... | Answered on Apr 30, 2019
Config Mode is depress 2 and 6 and power on. Diagnostic Mode is depress 3 and 6 power on. This is a Lexmark machine with a Konica Minolta logo
Konica Minolta... | Answered on Apr 28, 2019
The fuser (The Hot Part) and the machine are not from the same region. For example: North America and Africa. Check where the machine is from and fuser came from.
Try this once if it does not work contact a KMBS Technician:
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Reset key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If you do this to often you might cause a fire that will ruin a perfectly good day/ weekend!!!!!!!!!
Konica Minolta... | Answered on Apr 27, 2019
Konica Minolta Bizhub C451/c550/c650 Toner Magenta A070330 Logo
2 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
bizhub Konica Minolta
  • bizhub Konica Minolta
Most Popular Question
iam getting p21 c650 developer
  • Office Equipment & Supplies
