Our saeco magic has started to continuously grind the beans, when we start a brew cycle. We have to turn the machine off to prevent it from grinding the whole hopper and jamming up the brew unit. Many thanks.
Hi You have a micro switch on the doser that is in need of a replacement. It is a special micro switch that is just for the doser. It is very sensitive. If the micro switch is not activated the grinder will run until it times out, but the coffee will fill the brew unit and that could break the brew drive.
I had a similar problem
Mine was caused by an "oily" type of coffee beans. Grind was accumulating in the grinder.
I did open the machine and cleaned the grinder physically. At least, try to remove all beans and sucked with a vacuum the interior of the grinder screw.
Grinder adjustment set too low. Increase the setting to 18 and try again, after it grinds and starts to brew push the brew to stop the cycle. Repeat the steps again. If it works when it is grinding turn the big knob back down but to a mark 2 higher than you had it before. When the grind gets to fine the ground coffee compacts in the grinder and passage way then you get the message bean hopper empty. Making the grind a little coarser prevents the grinds from compaction. If you are using oily beans (Shiney) they can glue themselves together and cause the same symptoms but the fix is the same. Make it coarser. If it didn't fix the problem you will have to dissassemble the grinder and clean, then readjust.
Try setting the grind to the coarsest setting, if you still have the same problem, check the wire connections to the board, it might have been reversed.
Hi The grinders run on a timer. If the grinders does not fill the doser in time you will get a light saying no beans. If this happens and there are beans in the hopper push the lever to the largest # and push the brew button again. This will clear the light and it should brew. If it is at the largest # already your beans are probably shiny and there is to much oil in the beans and this is what is clogging the grinder.
Sounds like dosage is too high and grind is too fine.
Rule of thumb with any saeco unit.
Do not grind any finer then 2 or your looking for trouble.
Open grinder, clean it out with a vac. Slapped it back on.
The reason it stops is grind is too fine, and the machine doesn't have enough pressure to pass threw the grinds, creates back pressure in the machine and the unit failsafes after a certain amount of time with and pressure.
in the self test does it flush the unit ?
If not you have to prime the unit by allowing it to pump hot water through the frothing valve. Open the valve and the pump should pulse water out. After this the machine should indicate it is in the operating mode for coffee
