20 Most Recent Saeco Primea Cappuccino Touch Plus Coffee Maker Questions & Answers
Primea touch plus stuck on milk clean/rinse
My Saeco Primea Touch Plus is stuck in milk rinsing cycle. HELP
11/10/2022 6:46:40 PM • Saeco Primea... • Answered on Nov 10, 2022
2answers
Grinding and dumping coffee without making a cup.
Check the grind it might be too fine, then check the screen under the red o-ring in the brew unit it might be blocked.
2/8/2018 2:24:53 AM • Saeco Primea... • Answered on Feb 08, 2018
Error 5 message on lcd screen. What does this
That means prime the water circuit. It should prime by itself. If the machine is making noise and still failed to prime, you can do it manually by going into test mode , set the multi valve to hotwater position and operate the pump . When the water flow freely turn off the machine and restart it. Hope it will help.
1/14/2018 9:41:02 PM • Saeco Primea... • Answered on Jan 14, 2018
2answers
My Saeco Primea Cappuccino has stopped dispensing
If you don't perform the milk cleaning process for 21 days, the machine will blocked you from dispensing milk product.
3/28/2017 8:53:34 PM • Saeco Primea... • Answered on Mar 28, 2017
Saeco Primea Cappuccino must be reset I recive
Hi,Ive just recieved an email saying that your having some problems with your machine. Its hard to keep up with all the error codes on the hundreds of machines on the market. Faulty grinder usually dont give an error code. The grinder will just not work if its faulty, which tells me theres a problem with grinder. If your showing an error 1, i'd be looking at the steam heating circuit. Faulty thermoblock, thermostat, solenoid, etc. Anyway, something has led you to replacing the grinder, so ill see if I can help. Some machines need to be told that it has been fixed, which is done through the programming. You know when you go in to the cleaning program, thats where it may have to be told. The grinder also has other electrical sensors which maybe at fault. On one of the wires that connect to the grinder is a little square thing that sits in a holder on the grinder. It maybe faulty.(not common fault that part). The machine will usually reset itself when you turn it off at the main toggel switch, and unplug it from the power point. When you turn the machine back on, it will do a self dianostic before it starts to heat. but as I said before, the grinder usually isn't part of the self dionostic on start up. If you turn it back on and error code comes back up, id be looking at thermoblocks or thermostats. If your still having troubles, give me more details on how the machines full operation is working. If the grinder is at fault, everything else should be working. Thanks Darryn
1/8/2017 10:34:52 PM • Saeco Primea... • Answered on Jan 08, 2017
Error 1 - How to Resolve Grinder A Blocked?
The grinder is the problem. Inside the grinder is a white gearwheel. Change the gearwheel (cheapest way) or change the grinder and reset all errors from service menu.
12/24/2016 6:37:43 PM • Saeco Primea... • Answered on Dec 24, 2016
Message erreur E(5) sur saeco xelsis
We are a Saeco Service Center and can help with your issue. Service Center for Saeco Gaggia Rancilio Spidem Starbucks Espresso Machines
6/3/2015 3:45:44 AM • Saeco Primea... • Answered on Jun 03, 2015
What is problem of coffee grinder not working
if the machine is ready to go and the grinder not start check to see if is not block the grinder blade and if not block change the grinder with the same voltage one 120V or 220V
2/20/2015 4:15:24 PM • Saeco Primea... • Answered on Feb 20, 2015
I have. Saeco primea touch plus bean to cup coffee machine. It counted down to descale and once it started the descale operation it will not stop. How do I get the machine back to operating mode
once you start this cicle you let it to finish. until it doesn't finish it not work. you read what the machine say on display and it will work
2/15/2015 2:26:26 PM • Saeco Primea... • Answered on Feb 15, 2015
2answers
Replacement multi valve(micro switch) SUP 030 ADR
there are 2 micro switches on the multi valve i have 4 spare ones if your interested [email protected]
1/20/2015 6:58:46 PM • Saeco Primea... • Answered on Jan 20, 2015
Sup030adr
You can fix this problem from your machines menu.It is something that you must do step by step and it is difficult to write it down.If you still have the problem contact us and we will do it over the phone together.
5/8/2014 6:55:20 PM • Saeco Primea... • Answered on May 08, 2014
How to go into test mode
SAECO PRIMEA TOUCH PLUS 8821e4cc-2172-440a-820a-dbff67ca891d.jpg 715187e1-0532-4c04-b9a3-8fa335c829a3.jpg
5/4/2014 6:43:43 PM • Saeco Primea... • Answered on May 04, 2014
Saeco Primea Cappuccino Touch Plus Coffee Maker Logo
174 questions posted
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Saeco Coffee Makers & Espresso...
  • Saeco Coffee Makers & Espresso...
Most Popular Question
milk drawer won 39 t close
  • Coffee Makers & Espresso Machines
