20 Most Recent Saeco Magic De Luxe Espresso Machine Questions & Answers
First, I'm NOT a Saeco technician, But I have worked on similar machines. Sounds like your pulling too large a puck (doing a double shot with a lot of coffee instead of pulling two separate shots.)
* Grounds may be too large and taking up too much space for the group to compress properlly. Suggest checking you grinder calibration. There is a you tube link below.
Aloha, ukeboy57
https://www.youtube.com/watch?v=5M5WmOYzTAU
Saeco Magic De... | Answered on Jan 19, 2018
You have to remove the coffee bean hopper, there are two screws on it. Below it is the grinder and there must be a rubber seal between them. Perhaps it is crooked or broken, and then the coffee beans pass and fall down.
Saeco Magic De... | Answered on Apr 30, 2017
turn the hot water / steam knob on to 'ventilate' the pressure from the machine. The ventilate /overtemperature message will disappear when ready (few seconds usually)
Saeco Magic De... | Answered on Mar 01, 2017
Hi
The loud clicking noise is a broken brew drive. This usually happens when you use the pre-ground button but put more than the level scoop into the brew unit. The brew unit can't compress the coffee and jams the brew unit which breaks the drive gears. Drive gears have to be replaced. I have some drive units complete.
Saeco Magic De... | Answered on Sep 08, 2016
Couple of things.
Magnet in the water tank could have gone bad in which case you need a new water tank.
2. Sensor for the magnet could have gone bad. Which case you need a new sensor.
3. Flowmeter could be dead in which case it won't feed water to the system, If thats the case its a new flowmeter.
4. Pump. If the pumps not working, it won't feed the flowmeter, which in turn won't feed the system. You'd need a pump in this case.
Its one of the 4. Unfortunately its not an exact science, its a trial by error type thing.
Cheapest way is to send it to a service center. They'll know right away when they open it up. They can also diagnose quicker.
Saeco Magic De... | Answered on Jul 04, 2016
since, the adjustable dual-spout dispensing head can be easily raised or lowered allowing different cup sizes. Espresso cups (4 oz.) or coffee mugs (8 oz.) can easily be accommodated.
Saeco Magic De... | Answered on Jun 10, 2016
easiest thing to do is put it outside to dry or use a blow drier to dry it up, it should be ok
Saeco Magic De... | Answered on Sep 24, 2015
generally when the pump wont prime this means you have to take the machine in to see a tech. with that being said, do you have the newelectronx 102? might be needed in case we need to open saeco. but lets try this first, your grind settings is too fine for the beans and machine combination. i would suggest go two notches coarser. then brew four times to clear through the mixture of the old and new grind settings. make sure your beans arent to oily. and do a weekly cleaning
Saeco Magic De... | Answered on Aug 06, 2015
Do you have power to the heating element?
Saeco Magic De... | Answered on Jul 18, 2015
Saeco Magic De Luxe Espresso Machine Logo
513 questions posted
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Saeco Coffee Makers & Espresso...
  • Saeco Coffee Makers & Espresso...
Most Popular Question
water light flashing saeco magic de lux
  • Coffee Makers & Espresso Machines
