SOURCE: Jura Capressa E9 Leaking
Your spout is probly cracked (a common problem). It won't hurt the machine if you want to live with making one cup at a time to catch it all.
If you want to get it repaired go to www.hotncold.com Click on Jura Repair for shipping instructions. We can turn the job around in 24 hours. The repair will also include a free software update.
SOURCE: how do you remove stones from the grinder of a
Disassembly of the grinder is most likely due. There are springs and ball bearings in there so be careful not to lose any parts. I learned that the hard way. I can send a pictorial, written in German, but helpful. e-mail me at [email protected].
Mike
SOURCE: Describe your Jura Capresso Impressa E9 Espresso
You can find some detail procedure in this tip below
http://www.fixya.com/support/r5713182-jura_capresso_impressa_f9_malfunction_8
Try it since it have help some other with same problem.
SOURCE: The drawer will not go
You should visual check inside the drawer compartment. There might have some coffee dregs that fall behind the drawer and this is what blocking it to go all the way in. There is a limit switch that is closed only if the drawer is in its place and when this switch is open the machine give the massage "missing drawer" light on. So you use a brush and a vacuum cleaner to clean the drawer depart very good from any coffee remains in order the drawer to sit very good in its place so the limit switch will switch off.
SOURCE: jura capresso e9 water not coming through spout
Use a pin or a needle on the spout to clean the nozzle head. Most of the time this is due to useing to fine a grind in the machine. You may have to clean the head this way more then one time to get it to start working again properly.If you have any further questions message me back.
Thank you
Rick
