Sylvania 6842PE 42 in. HD-Ready Plasma Television Logo
p
patty burmeister Posted on Nov 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv just went blank red light (stand by) light is flashing. tv will not turn on any suggestions
Corky's Craft Shop
Level 2:
Novelist:
  • Expert 210 Answers
  • Posted on Nov 03, 2013
Corky's Craft Shop
Expert
Level 2:
Novelist:
Answers
210
Questions
Helped
75947
Points
482
My suggestion would be to go the section marked TV repair, not vacuum repairs.
4 Related Answers
Anonymous
  • 16 Answers
  • Posted on Oct 25, 2008
SOURCE: TV won't turn on.
The problem is the digital main board if you can get ashop to order it for you its easy to replace yourself four screws and three or four plug in connectors.
Anonymous
  • 63 Answers
  • Posted on Jul 05, 2010
SOURCE: tv comes on, green light flashes several times,
common problem with that model is the backlight inverter, 1 or more of the six transformers may be bad.also check for bad capacitors.the tedious way to check is unplug each and plug in each one at a time but unplug the power from the tv each time you check one or you will get a nice jolt. the one that doesnt light the lamp is bad.or take each transformer off and check the primary and secondary coils if you find one open coil. the transformers cost between $8 and $20 each.it has a substitute part.
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jun 22, 2011
SOURCE: Red stand by light flashs. TV will not turn on.
It is in safety shutdown which can be due to bad power supply (bad caps, blown components), or it is detecting shorted circuits so it goes into shutdown mode. It will require in-depth troubleshooting.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
walesarumi
Wale Sarumi KomputerSolution
  • 6993 Answers
  • Posted on Sep 12, 2011
SOURCE: Tv was working fine,no problems! Then went to
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
First, remove the power cord from the wall, wait for about 5mins, then plug it back into the back and turn the TV on. If it still doesn't turn on, press the ch+ or Ch- button on the TV. If this still doesn't help, then it confirms that the TV has developed a power problem.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
MY SONY TV LCD MODEL KF-50WE620 screen went blank. When I turn on the green light it blinks on 40-46 times every second, then turn to red color to Stand mode and blinks for 160 times, then move to power...
There is no reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Tom Miller
Broadcast Eng
HL-R5667W Picture just went blank, no sound. turn on tv the timer,lamp and stand by/temp light all flash. replaced lamp still same issue heard intermittent whirling fan rubbing sound before it went bad
Sounds that tv got color wheel problem that will be replaced.
If you are handy with electronics stuff repair then replace color wheel in light engine of tv to solve its issue.
1helpful
2answers
Plasma tv stopped working
hi i have a pioneer plasma tv pdpro4e all it doses is flash green red green red and on the mediar reciver as well tv dont come on help please
3helpful
POWER STAND-BY LIGHT KEEPS BLINKING
part# 191002393 is the thermal fuse.Located on lamp housing.
3helpful
Cannot get tv out of stand by mode..
upon hitting the power button, the red light showing on the front of the tv should flash a couple of times, the screen should come on and the light goes off..the red "stand by " light stays on and we cannot get the screen to come up..needless to say, cannot get to the menu to change any display options...any suggestions?
3helpful
4answers
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
2helpful
3answers
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
Fujitsu plasma went blank
Need to have the power supply checked by a qualified technician.
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
