20 Most Recent Philips 32PF5321 32 in. HD-Ready LCD Television Questions & Answers
3answers
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
11/29/2011 5:51:30 AM • Philips 32PF5321... • Answered on Nov 29, 2011
I HAVE A PHILLIPS flat
look online you can buy a adapter for about 15.00
8/3/2010 12:57:21 PM • Philips 32PF5321... • Answered on Aug 03, 2010
A red shadowy image appears instead of the actual
your panel is bad you need an LCD sorry
11/23/2009 7:58:54 PM • Philips 32PF5321... • Answered on Nov 23, 2009
Philips FlatTv problem
POWER SUPPLY PROBLEM TRY UPGRADE POWER SUPPLY KIT FROM PHILIPS
8/31/2009 10:56:18 PM • Philips 32PF5321... • Answered on Aug 31, 2009
2answers
Remote control
Try replacing the battery in the remote. CR2025 or equivalent.
8/31/2009 10:43:14 PM • Philips 32PF5321... • Answered on Aug 31, 2009
My Philips TV set won't show channels newly changed to DTV.
You need tot perform Autoprogram in TV to store new channels data and TV will show you digital channels too.
On Remote Control, Press Menu >> Installation >> Autoprogram >> OK
TV will store all available channels via Antenna (digital and analog)
Hit "add a comment" button for further query / info.
Thanks.
4/22/2009 10:19:56 PM • Philips 32PF5321... • Answered on Apr 22, 2009
Connecting my MAC to my LCD TV!
Do you have a DVI port on the LCD screen? Please tell me what connections you have on your macbook and your TV. There may be a converter.
Normally HDTVs can only be hooked up through S video or DVI Depending on your video card.
10/24/2008 6:03:19 PM • Philips 32PF5321... • Answered on Oct 24, 2008
Television
you can press both volume buttons on the set to bring up the televisions menu. From there you can use channel and volume buttons to navigate the menu.
9/15/2008 9:01:48 PM • Philips 32PF5321... • Answered on Sep 15, 2008
Philips LCD 42PFL3603D/F7 won't stay on until I've held the power button in a few times. The display comes on, then I hear a click and it shuts off. After a few cycles of this it stays on
Remove the cover on the back of the tv. Look for swollen or leaking capacitors. They kinda look like batteries. If they are bulging or leaking then that is your problem. You will have to de-solder the old ones off. Then solder the new capacitors onto the circuit board. Capacitors will cost about 20 dollars and installing them isn't that hard to do. It will fix your tv 99% of the time. So it is worth a try!
2/21/2024 9:36:48 AM • Philips... • Answered on Feb 21, 2024
I have Philips TV mode
I'm assuming that you have checked that the sound is not muted. To confirm that a reset to factory settings is the next procedure: Menu - Setup - General - Factory settings. If you don't see/hear any modifications then it's a hardware defect, not something with the settings.
This happens when the tv thinks that the headphones are used. Simple test to confirm that: plug in a pair of speakers and see if you get the sound on them. If you get and the situation doesn't changes when you unplug them then this is a mechanical defect: the small switch inside the headphone jack is faulty and keeps signaling that the headphones are plugged in when they are not.
The only way to fix that is to replace the jack, which involves a very delicate soldering procedure , one that only a good repairman can do - you must call one.
12/13/2023 4:44:25 PM • Philips... • Answered on Dec 13, 2023
Philips DVP3150V/37 DVD VHS combo Player. I am Looking for a universal control for Philips DVP3150V/37. Which one will work.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote How many would you like?
Genuine PHILIPS NA725UD DVD VCR COMBO Remote ...
eBay https://www.ebay.ca > ... > Remote Controls Genuine PHILIPS NA725UD DVD VCR COMBO Remote DVP3150V/37 ; Quantity. 4 sold. 8 available ; Item Number. 143886913897 ; Compatible Brand. For Philips ; Accurate ... $67.67 · ‎In stock
PHILIPS 996500027557 DVP3150V37, DVP3150V, ...
eBay https://www.ebay.ca > ... > Remote Controls PHILIPS 996500027557 DVP3150V37, DVP3150V, DVP3150 REMOTE CONTROL ; Model. DVP3150V ; Type. Remote Control ; Accurate description. 5.0 ; Reasonable shipping cost. US$59.95
Buy PHILIPS NA725UD -996500027557 DVD/VCR Combo ...
ReplacementRemotes.com https://www.replacementremotes.com > philips > buy-... PHILIPS NA725UD-996500027557 dvd/vcr remote control for DVP3050V, DVP3050V/37, DVP3050V/37B, DVP3050V37, DVP3050V37/VCR, DVP3050V37B, DVP3150V, DVP3150V/37
12/5/2023 4:44:13 AM • Philips... • Answered on Dec 05, 2023
ILive Sound Bar. I need the code for Philips Universal Remote to program my iLive Sound Bar please?
Best advice here https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote So many codes, good luck with that :>)
3-Digit Codes
  • 856
  • 734
  • 837
4-Digit Codes
  • 2113
  • 3175
  • 0816
5-Digit Codes
  • 33279
  • 72303
  • 32113
  • 23175
  • 33175
  • 42113
  • 31957
  • 43175
iLive remotes https://www.google.com/search?q=iLive+Sound+Bar+replacement+remote ..
11/19/2023 4:56:05 AM • Philips... • Answered on Nov 19, 2023
Needing to upgrade software on
yes i need software upgrade APPLICATION
11/18/2023 5:21:08 PM • Philips... • Answered on Nov 18, 2023
2answers
My rmt-d197a remote, i am trying to pair with my Philips t v
In order to pair your RMT-D197A remote to your Philips TV, follow these steps: 1. Power on the TV with the remote. 2. Press and hold the Setup button on the remote until the red LED light blinks twice. 3. Input the four-digit code that corresponds to your brand of TV on the remote. This should be found on the enclosed code list. 4. Release the Setup button. If the code is correct, the red LED light will blink twice. 5. Aim the remote at the TV and press the Volume Up button. If the TV responds, the remote is paired correctly.
10/31/2023 4:44:00 PM • Philips... • Answered on Oct 31, 2023
I need code for Philips t v using sony#rmt-d197a
The code you need to program your Philips TV using the Sony RMT-D197A is: 741
10/31/2023 3:27:55 PM • Philips... • Answered on Oct 31, 2023
I am looking to download Life View Philips software
Just to be clear, we are FIXYA, we aren't Philips, we just have a category for handy filing. The software isn't available online, just drivers. You would have to contact Philips direct. https://www.google.com/search?q=Philips+lifeview+software ..
9/24/2023 2:19:55 AM • Philips... • Answered on Sep 24, 2023
2answers
Philips 32PFL4664/F7 A parts
This sounds like a panel issue Sarah, if this is the case the set isn't repairable.
9/2/2023 9:52:08 AM • Philips... • Answered on Sep 02, 2023
Philips 3385v dvd/vcr recorder, brand new, Video plays only in fast forward
if new return it
6/30/2023 12:39:24 AM • Philips... • Answered on Jun 30, 2023
Philips 32PF5321 32 in. HD-Ready LCD Television Logo
16 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
philips flattv problem
  • Televison & Video
