20 Most Recent Samsung HLR5667W 56" Rear Projection HDTV Questions & Answers
Feel better now?
Tried a new lamp or is it now very old and damaged the main board?
Samsung HLR5667W... | Answered on Sep 20, 2017
The ballast board controls the lamp. The wires from the bulb attach to the ballast board. That board is your problem.
Samsung HLR5667W... | Answered on May 15, 2017
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Samsung HLR5667W... | Answered on Apr 21, 2017
Yes, this is considered a rear projection TV.
Samsung HLR5667W... | Answered on Jan 31, 2015
Hello, it sounds like the color wheel may have failed. Was there any noises, like a high pitch sound before it went out? If the color wheel isn't turning at proper speed, the set won't start up by shutting down the lamp protection circuit.
Samsung HLR5667W... | Answered on Jul 10, 2014
Hello, are there any sounds coming from your television? If something happened to the colorwheel I dont think the TV would come on at all, I would by instinct take a look at replacing the DMD chip.
Samsung HLR5667W... | Answered on Jan 16, 2014
The whining if it sounds like a mosquito type whine! it can be a capacitor, i have same issue, you can usually hear when u are on standby but if your hearing like a "wheel of fortune"! and slowing down would likely indicate it's a fan which is possibly covered in dust and the whining is the fan stopped trying to power forward or it slowly moving and slowing down. If you think it's the fan you should unplug your TV to avoid the fan burning out then have someone who knows what their doing take a look at than fan for you and clean the dust away from it, you may be able to get some access through vents in the side and can try your vacuum cleaner in those vents while TV is unplugged but i'd not go messing inside a TV without wearing some rubber gloves!
Looks like the engineer would need to remove TV casing, check fan to see if it is blocked with dust or not, or if just failing for other reason then either clean or replace. If you don't get it done and the fan fails to cool the TV your risking other vital components overheating and breaking for good so best get it looked at, sounds like the fan to me...
Samsung HLR5667W... | Answered on Nov 23, 2013
Hello, It may be the new lamp is bad causing it to arc inside the lamp. contact who you bought the lamp from and see if they will replace it....tks
Samsung HLR5667W... | Answered on Nov 10, 2013
take the back of the TV off then take the power sores out and put a new power sores
Samsung HLR5667W... | Answered on Nov 02, 2013
I would guess that it could be the main board going bad. Check all our connections and wiring. You should call places like Tri-State Module and they can probably send you a part or repair for way less than 500 bucks.
Samsung HLR5667W... | Answered on May 29, 2013
Had the exact same problem with our tv the mother board is completely fried when the green lights streak vertical across the screen.
Samsung HLR5667W... | Answered on Apr 12, 2013
Samsung HLR5667W 56" Rear Projection HDTV Logo
182 questions posted
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
View Most Popular
HL Samsung
  • HL Samsung
Most Popular Question
samsung dlp hlr5667w went blank just
  • Televison & Video
