SOURCE: inspiron 1150 screen is black
It is one of three things usually Bad cable at the hinge, Failed inverter board, or failed backlight. Probably inverter. Not to difficult to repair. Check cable first because it is inexpensive and easy. Check the inverter and replace if needed . Sometimes you can buy one used cheap with a bad motherboard and swap the top.
SOURCE: Dell Inspiron E1705, Faint Black Screen on Battery Power
the first thing i would do is do a bios update for the machine whilst using AC power, that may well iron the problem out, if not then there is a problem with the laptop itself i.e. a power drain, sizzling and popping noises is not good at all and could damage the machine further, remove the battery and check the connections on the laptop, dust and hair conduct electricity, it could be as simple as that, it is also a known fact that some lithium batteries are faulty and have been known to blow up whilst in use.
Go to the laptops support website to find out if they have been having problems with batteries and if there any returns proceedures
best regards
SOURCE: Micro phone not working in my DELL Inspiron 6400
Though I have inserted a microphone plug at Del 6400 socket still my laptop microphone system is not working , please help
SOURCE: Dell XPS M1330 - Backlight not working
If you are having issues with a backlight I would check the lcd inverter first. It is usually 20 dollars on ebay. I would avoid contacting dell as they are no help to people that are out of warranty.
SOURCE: Inspiron 1525..black screen. The screen is black
or screen probably is burned...
or inside crystals are broken..
u have to buy a new laptop
