20 Most Recent
Epson Stylus 1400 InkJet Photo Printer Questions & Answers
The screen saying the printer at the end of it service
end of it service = the printer has an expected number of pages it can print, beyond that the printer will start to fail out of old age and wear. Both printers have reached that limit, nothing more that can be done to revive them. Junk them and buy new ones.
The paper just feeds through my Epson 1400 without
what? you expect me to give you an answer to my own problem for nothing while you want to charge me $20 for "maybe" some help to resolve my printer issue? You've got to be kidding! What a "chintzy" way to make a buck!
Epson 1400 cartridge carriage jammed
The cleaning unit may still be engaged with the cartridge carriage. There may be a release mechanism on the side of the cleaning unit. The cover will have to be removed to see if that is the case. Another cause could be that the shaft or rail that the carriage travels on is quite dirty. It can be cleaned with alcohol to remove the dirt. That might be what is loading down the motor. Good Luck.
Epson Stylus Photo 1390 Paper Jam
It PW sensor error. For "Normal Quality" mode, the PW sensor will not work for "reading" paper existence, but for "Fine", photo and best photo it work. PW is paper widht. Small sensor at bottom side of carriage, near the head. Dirty or short circuit may be.... Can you fix it?
Red paper and ink lights blinking
red paper light is blinked as it is indication that plz insert paper in your printer, and ink light blinks because your printer is low on ink, kindly get your printer cartage refilled.
Both lights on Epson 1400 are flashing, but
Same problem here. I found out that the problem is the waste ink pad needs to be replaced and I can't find one anywhere. Then after that is done, you have to use a utility software that is availabe only for PC and I a Mac user. I have a PC I can run it on luckily, but too bad for those who don't. Problem now is, I haven't found the software that supports the 1400. Sounds like sabotage by Epson to force us to buy another printer. If so, I'll switch to HP.
