20 Most Recent
Dell Inspiron 1000 Notebook Questions & Answers
I need window vista home basic product key
If you purchased the laptop with vista on it, the key should be on the underneath of it's case. If you are upgrading, when you buy the product, it comes with a product key. If you are upgrading, why not try windows 7 which is quicker, more stable and less memory hungry.
Kind regards
Dell PP29L pwers on but screen remains black
If all the answers above do not work, it is possible that your video chip is failing. Laptop video chips are embedded in the motherboard. Over time, too much heat becomes an issue and begins to warp the chip and it begins to lift up slightly from the motherboard creating issues with blank screens when powered up. I've had the same problem with several laptops brought to me for repairs and 90% of the time it was the video chip. For this problem you may need to replace the motherboard with the same exact motherboard which you can find on ebay fairly cheap, and then if you don't feel too comfortable opening your laptop take it to a computer repair place and have it replaced.
Inspiron 1000 doesn't save cmos settings
HiAs you said that you haven't used the computer for long time then it could be the motherboard which has gone faulty not the HDD or DVD.Try to use the new HDD with this old motherboard.Or else you can seek help of Any Geek Squad or computer vendor.In case if you have any more trouble do contact back in Fixya.Thank you
How can I reset bios password on asus notebook ?
bios password reset methods depend on model & how its designed,
in laptops cmos battery reset will not remove bios password.
you can reset bios passwords by:
1. Entering master password, if it shows password disabled with Error CODE after failed attemps,
2. shorting bios reset jumper located anywhere near the ram slots in motherboard
3. Re flashing the Bios Chip
No sound
Yes you have to install the drivers for your sound card.....this always happens when you install XP it fails to read what drivers are in your sound card which is on board. Do you have the original drivers do you know the sound card onboard?
Bios password reset
hievery laptops different but normally u can remove the cmos batterywhen you put it back and start the laptop you have to go into cmos setting set the time date and year press default settings and save restart and that should reset the biosaries
While I am typing on the keyboard the cursor will
A couple things can cause this to happen....
1. While you're typing, your hand or thumb might be hitting the mouse area near the keyboard which causes the mouse to move around.
2. You could have some heavy resource program running in the background which slows the system down.
3. You have an infrared mouse without a proper mouse pad so the infrared causes the light to bounce around causing issues.
4. A virus :(
