SOURCE: Linksys Broadband Router Model WRT4G manual
You can download the manual from HERE.
Goodluck,
Please don't forget to rate the solution.
SOURCE: linksys password...
I think you are wrong , some model has blank password, for example:
SPA-3102
There is also some model that use blank username and password 'admin' to start administrator account.
(20 years selling and fixing this stuff)
It is possible default settings are different in different countries, I am in UK.
SOURCE: Username & password for WRT54G Linksys Router
As this is posted under WRT54G router - the default IP for that model really is 192.168.1.1
Look at the bottom of the router and locate :
(right under the word Linksys)
Exact Model and Version
If it is a WRT54G :
disconnect all ethernet cables leave it ON
Press and hold the reset button for 10 - 15 seconds (make sure all the lights flashes)
SOURCE: I have an unsecured router ,linksys wireless-g 2.4
There is no need to ask for a username or password. Just log in the settings' page for your Linksys with your browser (typically it's http://192.168.1.1), provide the username and password to connect with the router and make the settings you like for the Wi-Fi name at WLAN SSID section and the password you like at the security section. At the end hit apply (or save). I advice you to make all these settings while you are connected with an ethernet cable at your Linksys, to avoid being locked out in case of a problem.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
If you have forgotten your Linksys router password, the easiestthing to do is to reset your router to the factory default settings. To restore therouter configuration to factory defaults, hold the reset button on the unit for30 seconds.
Once your router is hard reset, you will need tologin and reconfigure it again.
To reconfigure your Linksys,connect a PC to one of it's Ethernet ports, load a web browser, and go to theURL http://192.168.1.1/. This will take youto a popup box which asks you to enter a username and password to login to yourrouter.
Linksys Default Password
On older Linksys routers, the default username is blank and thedefault password is "admin." On newer Linksys routers, both thedefault username and the default password are set to "admin."
Once you are past the login screen, you are able to reconfigurethe Linksys router.
You want to go to the management tab and change the administrator password tosomething else to keep others from accessing your router.
