SOURCE: how does a 9s-4h/c danco stem install.
the spring goes in first then the rubber seat goes on top.put them together first on a small screwdriver,insert on hole push down on rubber into hole it should stay.replace stem in reverse order of takeing off.
SOURCE: I bought a Danco 3H-10H/C, Hot/Cold stem. The
One of two things has happened. I'm assuming you only get hot water when you open the valve and that this is for a single handle control shower fixture. If so either this is the wrong valve for your shower control or it is installed backwards. Sometimes the valve can be installed at either 180 degree angles. See if it can be installed any other way. If so this may solve the problem.
SOURCE: I HAVE A DELTA FAUCET
order a moen replacement online from
www.plumbersurplus.com/Prod/Delta-Faucet-Company-RP24096.
SOURCE: Where does washer go for 12h-6h/c stem from Danco for faucet?
If it is red in color it is a #38 fiber washer and is the cap thread gasket.
1st turned water off under sink removed cartrage replaced with newone once I turned th water back on it started to stream water I thought it was bad so I removed the cart and it fell into pieces see pic. I o[t to buy another stem once installed same thang happened so now I think it's the seat, but pfisher did'nt know if it could be replaced?
