20 Most Recent Danco Faucet Cartridge Questions & Answers
The spring goes in first then the rubber seat goes on top.put them together first on a small screwdriver,insert on hole push down on rubber into hole it should stay.replace stem in reverse order of taking off.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Danco Faucet... | Answered on Aug 06, 2018
#1 THE FAT PART OF YOUR SPRING GOES INSIDE THE FAUCET ,AND SIT ON THE VALVE BODY(SEAT)
#2 THE LITTLE BLACK WASHER SIT ON TOP OF YOUR SPRING
#3 PUSH THE STEMS IN THE CORRECT SIDES HOT ON LEFT.CAUTION THERE IS USUALLY NOTCHES ON THE SIDES OF THE STEMS TO HELP YOU ALIGN THEM IN THE VALVE BODY,
4 PUT THE NUT BACK ON ,TIGHEN SLIGHTLY,TURN ON THE WATER TO CHECK ,IF OK RE INSTALL YOUE HANDLES
Danco Faucet... | Answered on Feb 11, 2014
Put the large part of the spring into the plastic or rubber washer first, then insert into faucet. I use a little of petrolem jelly for easy instlation.
Danco Faucet... | Answered on Dec 31, 2013
you have to disassemble your old faucet by using "Wrenches". than reassemble the new one
Danco Faucet... | Answered on Oct 11, 2013
Thae stem you got that said hot/cold were designed to fit old style cross handle faucets. So both hot and cold turned the same way. If the cold side you are replacing turns the opposite direction then you will need to get a cold stem. Danco does make them. Ask the retailer where you purchased the H/C stem. I hope this helps..
Danco Faucet... | Answered on May 13, 2013
change cold cartridge call danco if you can
Danco Faucet... | Answered on Feb 27, 2013
Danco Faucet Cartridge  Logo
60 questions posted
Top Danco Home Experts
Donni Steen
Andrew Bugbee
chedester
Level 1 Expert
Are you a Danco Home Expert? Answer questions, earn points and help others
View Most Popular
Danco Home
  • Danco Home
Most Popular Question
bought replacement danko faucet
  • Home
