Kohler Cimarron 2-PC Elongated Toilet with EcoSmart Technology, Left-Hand T... Logo
j
joan barrios Posted on Oct 28, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot tighten toilet seat - Kohler Cimarron 2-PC Elongated Toilet with EcoSmart Technology, Left-Hand T...
Lawrence Walters
Level 2:
Sergeant:
Champion:
  • Expert 426 Answers
  • Posted on Nov 29, 2013
Lawrence Walters
Expert
Level 2:
Sergeant:
Champion:
Answers
426
Questions
0
Helped
77453
Points
980
You can get a new set of bolts
How do you tighten the posts on a rak toilet
Look where the seat attaches to the toilet bowl. There are 2 nuts underneath.
Those are the nuts you tighten. they will hold the seat firmly.
Aug 19, 2014 • Home
How to tighten an american standard toilet seat
They all work pretty much the same. Feel around the top rim of the bowl near where the tank meets the bowl you should find one bolt underneath on either side of the toilet seat. Tighten the nut under there to tighten the seat.
1helpful
Self closing all in one tolet seat boxed, hidden screws, how to tighten
If you are trying to install a standard toilet seat on a special "smooth sides" toilet, it likely will not work. Most hidden bolt toilets come with a special seat because you cannot get to anything from below. This special seat has a set of expanding style bolts that are attached to the screw that is part of the seat. The plastic expanding bolt goes into the hole(s) on the toilet, and as you tighten the screw on the toilet seat bolts, they expand the plastic part in the hole of the ceramic toilet.
1helpful
Toilet seat slips
You will need to tighten the bolts holding the seat to the bowl. This video well help although the seat may not be the same as yours.
http://vodpod.com/watch/793915-tighten-toilet-seat-bolts
Toilet seat does not wont to close only using about a month
seat hinges were tightened out of alignment. Loosen platic nuts and tighten snugly, rotate hinges to bein line and tighten
1helpful
2answers
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
Toilet seat hinges are loosening
Most generic seats have a thin plastic cap that snaps in place over the bolt heads just behind the seat. Normally they hinge backwards so carefully pop them open with a flat blade screwdriver. Sometimes you can tighten the bolts from underneath even.
4helpful
Loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Sep 06, 2009 • Home
Top Kohler Home Experts
john h
ZJ Limited
ZJ Limited
Are you a Kohler Home Expert? Answer questions, earn points and help others
