1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
You can download driver from bottom link.
Other Companies Camera Drivers for Windows XP Vista Windows 7
Check for ventilation to start with. if its overheating this could be an issue, failing that, since you are already recovering the HD, I suggest that it maybe beyond recovery, as the recovery info.. is also held on the same disk
Testimonial: "I suspect that overheating did cause the problem. Solve that problem. Sense I am unable to recover from the HD couldn't I still be able to use a win 7 installation disk to wipe the HD clean and reinstall?"
If the hard drive is a WD ( western digital).. you need to remove it to see this, then the answer is most likely no. There seems to be a glut of WD500gb 2.5 inch drives failing. Having said that, you don't ahve much to loose. Make sure you use the windows disk to delete ALL partitions on the drive, and attempt a new installation. A giveaway as to the chances of success, is that if removing the partitions takes more than a few seconds... the drive will most likely fail completely, but always appear 'possibly recoverable'
My HD is a WD but 320GB none the less I tried the win 7 disk but only got to the setup is starting..... and than nothing. Looks like the HD is fried. Thanks for the information and help
