I have a short-arm Pinnacle Quilting Frame (free hand quilting) with a stitch regulator. I keep have a periodically problem with skipped stitches and or slight looping on the bottom of the quilt. I have a new Organ size 16 needle in and the feed dogs are at the proper height. I have thourghly cleaned the bobbin case! I am using a new Brother PQ1500S. Any help out there?
Try a different needle. Use a quilting or topstitch or even a metallic needle - one that has a larger scarf than normal. The scarf is the groove at the back of the needle where the thread goes while the stitch is being formed. Quilting threads often need more "room" there. I have been told that the Inspira quilting needles are good because they have a thread groove on the front and the back of the needle. Not tried them personally but might be worthwhile for you to consider.
For the looping, you could fiddle with your tensions a little either loosening the bobbin tension or tightening the top, or both. Only ever do this in very small increments. But the good news is that even the "professional" quilters do not have perfect quilt backs - just have a look at them at quilt shows!
Pam M.
