That error code is related to Paper transfer belt contact motor error
The paper transfer belt contact motor drives beyond the specified time during home position detection or contact operation.Broken harness or defective connectors. Disconnected connector of paper transfer belt contact sensor or motor. Defective paper transfer belt contact motor. Paper transfer belt unit not installed try to change the motor
SOURCE: Ricoh Aficio 3006 error sc452
SC326, First of all check that the laser slitglass is still there, I've seen a couple of machines where the slitglass has been missing completely and it's been throwing up laser SCs. Remove the laser unit. Clean all the toner and dust out of it. Clean the synch sensor very carefully. If codes continue replace the LD unit. They tend to fail on these machines due to excess dusting
SC452 ITB bad contacts check ITB lift lever might broke and cam on same shaft if both ok check harness of those contacts
