Computers & Internet Logo
t
tedman Posted on Oct 24, 2013
How do i establish a subnet with a A address - Computers & Internet
Christopher Sibiski
Level 1:
  • Contributor 22 Answers
  • Posted on Oct 25, 2013
Christopher Sibiski
Contributor
Level 1:
Answers
22
Questions
0
Helped
5889
Points
40
The subnet is determined by the subnet mask. Class A addresses are contained in the following range: 0.0.0.0 - 127.255.255.255. The most common use of a class A address is 10.0.0.0
In class A networking you may use a subnet mask from 255.0.0.0 all the way to 255.255.255.255
The subnet would work as the following example:
Network Address: 10.x.x.x
Subnet mask: 255.0.0.0
The first number in the above example would determine our subnet. So if you have 2 devices and you would want to put them in a different subnets you would want the first octet (octet is each number seperated by periods) to be a different number.
Network 1: 10.x.x.x
Network 2: 11.x.x.x
Unless these devices use a router to communicate they would not "talk" properly. Thus giving you 2 different subnets.
2helpful
NEED QUINTUM PASSWORD RESETTING
The detailed description of Configuring Terminal Software/Assigning IP address to Tenor DX is given below.If you need only RESETTING GOTO STEP 18.
1.From your PC, click on Start> Programs> Accessories> Communications> HyperTerminal. The Connection Description is displayed.
2.Enter a connection name (i.e., name for each unit such as Tenor DX 1 and click Ok.
3.Choose the connection port on your PC from the Connect Using drop down list box (i.e., Direct to Com1). Click Ok. The Com1 Properties window will be displayed. See Figure 3.
4.From the Bits Per Second drop down list box, choose 38400.
5.From the Data Bits drop down list box, choose 8.
6.From the Parity drop down list box, choose None.
7.From the Stop bits drop down list box, choose 1.
8.From the Flow control drop down list box, choose None. Click Ok. A connection to the Tenor unit is established.
9.Click on Call>Call. A connection to the unit will be established. The login prompt appears.
10.Enter a login name. The default login name is admin.
11.Enter a password. The default password is admin. (Once you are up and running, changing the password is a good idea for security purposes). Step through each of the following parameters and enter the correct values for your installation: IP address, Subnet Mask and Default Gateway.
12.At the Quintum prompt, type ei to reach the Ethernet prompt and then type config to change to the configuration mode.
13.To set the IP address, type set ipa followed by the IP address.
14.To set the Subnet Mask, type set subnetmask, followed by the subnet mask.
15.Type siprd to change to the Static IP Route Directory.
16.To set the Default Gateway IP, type change 1 g followed by the IP address for the default gateway IP.
17.Type submit.
18.Type maint to reach the maintenance mode and then mc. Type reset. A confirmation message will ask if you want to reset the unit. Type yes to reset the unit. The reboot enables the Tenor to incorporate the new settings.
19.Once the IP information is set, you are ready to configure the unit.
tip
How to setup VPN on a D-link Router.
Ok to Setup you VPN follow the instructions below. You can configure DI-804HV, DI-808HV, and DI-824VUP+ by web management interface. Type 192.168.0.1 (The LAN IP is 192.168.0.1 by default) in the browser, and then input user name: admin (there is no password by default) to pass authentication of web management interface. Then finish the configurations as showed below on Gateway A and Gateway B. Configurations of Gateway A 􀂾 Model: DI-804HV (DI-808HV, or DI-824VUP+) 􀂾 Firmware version: v1.40 (You can download the latest firmware on D-Link’s website.) 􀂾 WAN IP Address: 14.15.16.17 (Static IP) 􀂾 LAN IP Address: 10.5.6.1 (Subnet Mask: 255.255.255.0) 􀂾 VPN Configurations: 􀂄 Enable VPN function on Gateway A. 􀂄 Tunnel Name: toGatewayB 􀂄 VPN Method: IKE (Main mode) 􀂄 Local Subnet: 10.5.6.0 􀂄 Local Netmask: 255.255.255.0 􀂄 Remote Subnet: 172.23.9.0 􀂄 Remote Netmask: 255.255.255.0 􀂄 Remote Gateway: 22.23.24.25 􀂄 Pre-share Key: hr5xb8416aa9r6 􀂄 IKE Proposal (Please remember to add the correct proposal ID into the list of IKE Proposal Index when you finish inputting the following information.) 􀀹 Proposal Name: toGatewayB 􀀹 DH Group: Group 2 􀀹 Encryption Algorithm: 3DES 􀀹 Authentication Algorithm: SHA1 􀀹 Life Time: 28800 􀀹 Life Time Unit: Second 􀂄 IPSec Proposal (Please remember to add the correct proposal ID into the list of IKE Proposal Index when you finish inputting the following information.) 􀀹 Proposal Name: toGatewayB 􀀹 DH Group: Group 2 􀀹 Encapsulation Protocol: ESP 􀀹 Encryption Algorithm: 3DES 􀀹 Authentication Algorithm: SHA1 􀀹 Life Time: 3600 􀀹 Life Time Unit: Second 4. Verify the VPN connection Before you start to establish VPN connection between Gateway A and Gateway B, please make sure the Internet connection between Gateway A and Gateway B is workable. You can use “Ping Test” tool on Gateway A (or Gateway B), and input the IP address of Gateway B (or Gateway A) to see if there is any response from its peer device. Connect a PC (called PC_A) to the LAN port of Gateway A, and connect another PC (called PC_B) to the LAN port of Gateway B. Start to “Ping” PC_B on PC_A, then Gateway A will start to establish IPSec connection with Gateway B. If you can get “Ping” responses from PC_B on PC_A, then it means the tunnel has been established successfully. You can also check the “VPN Status” page with web management interface to verify the status of VPN connections. Figure 1: VPN status of Gateway A after IPSec connection has been established. Figure 2: VPN status of Gateway B after IPSec connection has been established.
Hope this helps
Here it is in PDF.http://www.vpnc.org/InteropProfiles/D-Link-DI.pdf
on Feb 11, 2010 • Computers & Internet
2answers
How do i establish a subnet with a B address
Subnet mask for 86 PCs is more than 64 and less than 128. it means that subnet mask is 255.255.255.128
You can have PC IP address in range 172.31.0.129 - 172.31.0.254
Can't find printer on network after establishing ip address on printer I've followed the procedure of getting IP address, Gateway etc, but when I try to install a driver on the computer, it can't find the...
are you still on the network, ping the printer ip address or eg Ping 192.168.10.4 -a -t, if you get a reply and you have an administrative access to configure the printer then you are done, but ensure you are on the same domain, same subnet mask and within the IP range for this network,
Regards,
Cannot link vpn. direct from internet provider works. when try connection via d-link dir625 does not connect. does allow internet access
Hope this helps
2answers
I have DWL2100AP i can open the IP address
To enter the menu of your device follow the following directions :
Your device default IP is 192.168.0.50 - Connect the device to your computer with an ethernet cable and set up your computer IP address manually, make it 192.168.0.49 , subnet 255.255.255.0 When connection is established, enter 192.168.0.50 in your internet browser, you will be able to reach the console.
Billionton USB : Class 1 USB Bluetooth adapter
before you try any step i tell you please disable your antivirus and firewall.
well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Linksys WMP45G will not connect to wireless modem
goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2.
ypur connection won`t drop after this.
Port forwarding
What is the manufacturer of your router so I can get a user guide and taylor the instructions if needed?
Generally I would statically address the device to be forwarded to. If your router address is 192.168.1.1 and Subnet mask of 255.255.255.0 and it's DHCP server controls address 192.168.1.100 for 50 leases to 192.168.1.149 then consider using the range 192.168.1.2 - 192.168.1.99 uniquely as static IP addresses. There are more starting at 192.169.1.150 but let's ignore them for now. In the network adapter to recieve port forwarded content assign a static IP address based on the above as say 192.168.1.15 with a subnet mask of 255.255.255.0 and a default gateway of 192.168.1.1. The DNS addresses should also be static however depending on your router there may be an option. Some routers allow their address to be entered as the DNS address and pass requests as appropriate to the DNS servers loaded in their lan configurations, otherwise you will enter your ISP supplied DNS addresses into the network configuration.
Now that we have established a stable IP address to forward the port to we need to tell the router everything it sees for port 5060 gets forwarded to IP Address 192.168.1.15 port 8000. If detailed instructions are needed I will need to know the manufacturer and model of your router.
Please provide the additional information and any questions in a response to this problem and I will respond when available.
Grand Canyon Tech
Grand Canyon Tech
