Dishwasher arms are not spinning and doing lousy washing job. It's a Moyer Diebel 501HT. What causes the arms to spin? A motor or just water force? I've checked and the top arm doesn''t seem to get water and the bottom does, just doesn't spin.
Hello there
First to check is the water level is it just cover the round filter and no more, or is it much lower from the filter. It seem you have not enough water in the tank to do the washing that is why you have a lousy washing job, not enough water to spray upwards don;t talk about the top spray arm , the water doesn't reach there at all.
You can check it out by manually fill the machine with water up to the filter and start the machine up when the machine is running open the door and you can see the water spray up to the top be careful the water will spray out to your face too.
This is only to check to see the motor is running normally.
If the water level is good ( that is just touch the filter) and the problem still there, then the other cause the problem will be inside the pump motor the part call the impeller may need changing.
Do you have the manual book so I can show you which part we're talking about and let me know where your district so I can tell you where to get the parts from . My email address is [email protected] God Bless Have a nice day, Dickson
