Posted on Oct 22, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My canon mg4220 printer indicates "offline" why?
Dana Newcombe
Level 3:
President:
  • Master 1,564 Answers
  • Posted on Oct 22, 2013
Dana Newcombe
Master
Level 3:
President:
Answers
1564
Questions
Helped
540490
Points
4667
What operating system are you running? I'll assume it's windows based and tell you that your best bet is to go to your control panel, then printers and cameras, then double click the printer icon you are presently using. When you see the box pop up, at the top left there will be a tab that reads "Printer" click it and where it says "Use printer offline" uncheck that box.
I have Canon TR4527 printer, 1303 error message keeps showing and there is no jam. help please!
Please remove your printer from the PC and uninstall the printer software. Now reinstall the printer driver software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
If the printer shows a jamming error then check the input of the paper feed as there can be some foreign objects that is obstructing the detector opto-coupler or the detect switch. clean and check or the sensor is faulty.
How can I add my canon printer to my chrome book?
Only if the Canon printer is on your home WiFi system. You use the Canon Print App or the Canon iEPP App to connect.. Or...
Add your printer to your Chromebook
  1. At the bottom right, select the time.
  2. Select Settings .
  3. At the bottom, select Advanced.
  4. Under "Print and scan," select Printers.
  5. Under "Available printers to save," next to your printer, select Save.
  6. Check that your printer appears at the top, under "Saved printers."
Set up your printer - Chromebook Help - Google Support
2answers
How to Set up Canon Pixma MX492 on Windows?
Installation and setting up your own printer is not as intimidating as it sounds. Before beginning you must know the name of your router. The following are the steps for Canon Pixma MX492 setup on Windows. Start the set up process on your printer and download the set up file on your computer. Select the wireless LAN setup and click ok. Download and run the file on your computer. Go to settings and select the drivers and printers option. Select the name of your printer and click ok.
https://connectmyprinter.com/how-to-setup-canon-pixma-mx492/
How to Set up Canon Pixma MG2522 in Mac Book?
The functioning of your Mac Book is a little different from Windows. It is possible that this may get you confused. Let's take a look at the steps for Canon Pixma MG2522 setup in Mac. Click on 'Drivers and software' options in your printer and chose the version of Mac OS you are currently using. Start downloading the printer driver on Mac. Then, double click the downloaded file to run it. Now, you have to select the 'Continue' button twice. Thereafter, press 'Install' to add the Canon Printer to your Mac Book.
https://connectmyprinter.com/how-to-setup-canon-pixma-mg2522/
2answers
Can a windshield be replaced on a 1998 dakota without removing the wiper arms
Whats hard about removing wiper arms easy job.Windscreen fitting harder if you get it wrong.
Change wyfi cennections
On Printer--Menu--Search For Connection--Then When Found Name--Enable
3answers
My printer keeps saying it's offline what could be wrong?
Canon is a Japanese brand that has spread its wings all over the world now. It is recognized for the manufacturing of cameras, camcorders, steppers, photocopiers, & medical equipment.
Similar to any hardware, even a printer has faults and problems while interacting with a different system. One of these issues is that it shows "Canon Printer Offline" even when it is properly connected.
Solution's of Canon Printer Offline:-
Solution 1: Restart the Printer Spooler service.
Solution 2: Disable Use Printer Offline feature of your Canon printer.
Solution 3: Reinstall your Canon printer software.
If, you are getting a Canon Printer Offline error to feel free Chat with Technician. If you are using a canon printer, it is possible that your printer cannot print correctly and then you find that its status is offline.
Contact Expert - Canon Printer Offline
2answers
Printer says it is offline. How do I make it "online" once again? Notification it shows: "The printer is offline. Check that the printer cable is connected and the printer power is on." Printer cable...
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ppobmi15
old marine
old marine
ZJ Limited
ZJ Limited
