My camera goes off after 2 minutes the screen goes blink and doesn't take pictures you have to cut it off then turn it back on if no motion it goes back off don't have instructions anymore what shall i do
Re: My camera goes off after 2 minutes the screen goes...
Try cleaning the battery contacts and the battery itself with a q tip dampened (not wet) with 91% rubbing alcohol. Then, in the main menu click to set all values back to Factory default.
P.S. You may retrieve your manual by going to your browser and type in just the model number of the unit with "pdf." minus the quotations.P.S. You may retrieve your manual by going to your browser and type in just the model number of the unit with "pdf." minus the quotations.
You can't post conmments that contain an email address.
1. Try cleaning the battery contacts inside the battery compartment.
2. Try removing the media card, then turn on camera. If its ok, then you have a bad media card, try formatting the media card.
No solution for you...but I have the same problem. I also had the green blob problem which sony fixed earlier this year. It happens on an intermittent basis. Screen goes off, standby light blinks green, then comes back on. Its off for maybe 1-2 min.
NAKE SURE YOUR FRONT COVER THAT GOES OVER THE LIGHT IS'NT ON TO TIGHT ALSO CHECK THE 2 SCREWS THAT MOUNT THE LAMP COVER MAKE SURE THERE NOT TO TIGHT AND THAT THERE BOTH SCREWED IN THE SAME AMOUNT AND ALSO CHECK THE FAN ON THE BACK OF YOUR T.V. AND CLEAN IT IF NEEDED
The LCD screen is black and I can't tace picture. But I can still view my pics. The camera goes thru all the motions like it is taking a picture but it is just coming up black.
