20 Most Recent RCA R52WM24 52" HDTV Projection Television Questions & Answers
Most times when you hear this kind of sound on a TV it is because the flyback transformer is bad (from what I can remember anyway!). Its been a while since I repaired TV's, so hopefully someone can verify my info. The flyback transformer steps up the voltage very high which powers the color tubes. If that is bad, you will get the thunk sound. Also, if memory serves me well, there is a high power output chip that could be bad as well. Please, anyone who knows TV's, please verify for me. It has been years for me!
RCA R52WM24 52"... | Answered on May 27, 2014
your menu will have the size on your tv
RCA R52WM24 52"... | Answered on Jan 13, 2014
the deflection board has failed. You would require the ITC222A deflection board which is the second board listed on the following page which has a warranty and comes with installation instructions
http://tvrepairworld.com/rear_projection_tv_circuit_boards/rca_circuit_boards
RCA R52WM24 52"... | Answered on Apr 09, 2013
if you are using coax cable to conn cable box to tv, be sure to use the analog ant conn on back of tv, and there is a switch on the back of the tv for selecting channel 3 or 4, for cable box use. be sure to turn tv to the same channel the switch is selected to, and always use the cable box to change channels/ programs, not the tv channel selector.
RCA R52WM24 52"... | Answered on Feb 28, 2013
The convergence needs correction. If its not able to be cleared up by running the auto convergence feature in the setu menu then you will need to repair the convergence. You can get free technical assistance and parts foor your RCA at www.tvrepairworld.com they are RCA experts with that chassis
RCA R52WM24 52"... | Answered on Feb 11, 2013
I replaced the screen on my 62 inch projection TV for about $50 and the the picture quality is good! Have a sheet of plexiglass cut to the EXACT size needed. BEFORE installation it MUST be frosted on both sides by either a fine particle sandblaster or by sanding it VERTICALLY on BOTH sides with a power sander and a fine grade paper.
If this is only an OUTER protective screen and the image is projected on the inner screen then DO NOT frost the replacement screen, just install it.
RCA R52WM24 52"... | Answered on Jan 11, 2013
Check your DMD board fan. Make sure it is spinning. This fan is the #1 problem for this model not turning on. This fan keeps the DMD board cool while working and if the fan does not spin your TV will not turn on. You might need to replace it if it is not spinning. If the fan is spinning, then check the color wheel. If it is not spinning your DMD board is not working and should be replaced.
You hearing a sizzling or slight pop sound?
RCA R52WM24 52"... | Answered on Sep 03, 2012
RCA R52WM24 52" HDTV Projection Television Logo
362 questions posted
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Televison & Video
Most Popular Question
children playing
  • Televison & Video
